Forums >> Revit Building >> Technical Support >> trimming trim corner.
Wed, Feb 1, 2012 at 12:23:24 AM | trimming trim corner.
Warchitect
4 Stars: 5 Votes
I want to trim the green trim on this existing drawing Im working on.
check out this image. how can I get the trim to not be that sharp bottom edge? I can't think of the solution to this.
Thanks in advance
Wed, Feb 1, 2012 at 8:02:56 AM | trimming trim corner.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you tried joining the geometry?  It looks like they are two different size trims.
Wed, Feb 1, 2012 at 9:33:07 AM | trimming trim corner.
If you apply your roof facia to both roofs in the same operation, then they will miter correctly.
Wed, Feb 1, 2012 at 12:09:41 PM | trimming trim corner.
Warchitect
4 Stars: 5 Votes
That worked great.!! thanks Hub!
I had a very small bit of roof projecting forward out, that needed a piece of facia to connect the two.
Corner Trim with Vertical Sweeps
Thu, Aug 31, 2017 at 2:32:51 PM
trim/extend to corner
Thu, Nov 4, 2010 at 6:10:31 AM
Help! Forgot how to trim with a radius corner.
Mon, Jan 8, 2007 at 8:25:35 AM
corner trim
Fri, Apr 2, 2004 at 2:17:39 PM
Sweep Corbelling Trim on the Corner
Fri, Apr 8, 2016 at 1:04:26 AM
Page generation time: 1.4443
