Forums >> Community >> Newbies >> How to change "opens with" settings?
Tue, Jan 31, 2012 at 6:52:55 PM | How to change "opens with" settings?
Scotty79
Scotty79 Avatar
I've got the Building Design Suite Premium insalled on my machine - which includes Revit Architecture, Structure and MEP. As a Revit Architecture user, I want my files to default to open in Revit Architecture when I double click on file icons in Windows Explorer, however my files keep opening in Revit Structure.
Does anyone know of a way to change this? I've tried right clicking on the icon and browsing for the program (revit architecture) but it makes no difference. As far as the computer is concerned the file opens with "Autodesk Revit" regardless of whether you select Revit Architecture, Structure or MEP as the program you want to open the file!! argh
Any help yould be greatly appreciated!
Wed, Feb 1, 2012 at 8:11:35 AM | How to change "opens with" settings?
I believe Revit files are always opened with the last Revit program used.  So if you have 2011 and 2012 installed and you just ran 2012, don't double click on a 2011 file that you want to keep in 2011.
For this reason, we tell all of our users not to use the double click process but to open the appropriate program first and open the file from there.  This process doesn't take any longer, just takes some discipline on the part of the user.
Fri, Jun 1, 2012 at 2:04:22 PM | How to change "opens with" settings?
ButchWilliams
I changed the registry setting:
\HKEY_CLASSES_ROOT\Revit.Project\shell\open\command
All I changed in the (Default) path was:
"Revit Structure 2012" to "Revit Architecture 2012"
Be careful changing the registry because incorrect settings could cause serious problems.
How do you change a "generic model" family into a "mechanical equipment" family?
Fri, Apr 6, 2018 at 6:18:19 PM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Revit Architecture 2009 - cannot open file using "file: open"..any help?
Wed, Jul 28, 2010 at 2:34:26 PM
How to make a "Model in-place" a "Family"
Thu, Mar 17, 2011 at 5:07:59 PM
callouts with "typ" label?
Mon, Sep 15, 2008 at 1:44:41 PM
Page generation time: 2.8036
