9 Users Online (8 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Nested Families
Tue, Jan 31, 2012 at 4:35:00 PM | Nested Families
JBRADLEY
Is it possible to Tag a Nested Family, and it's Host Family separate with two different equipment tags, and have both tags show up separately in a schedule?  For example,  Can I insert a family with 2 nested families into a project, then apply three tags with three different values and have it schedule that way?
Wed, Feb 1, 2012 at 7:17:06 AM | Nested Families
Sure ... the nested family has to be set to shared.
From your HELP:
shared family
A family of model elements that can be used to create subcomponents of a nested family.
When you use shared families to create a nested family, you can select, tag, and schedule the individual subcomponents in a project. (If subcomponents are not from shared families, Revit Architecture treats an instance of the nested family as a single item for selecting, tagging, and scheduling.)
See also nested family. For more information, see The Families Guide."
Thu, Apr 4, 2013 at 4:54:15 PM | Nested Families & Schedules
TerribleTim
Can I bump this one?
Here's what I've got. I have a family that has two nested families in it. I don't want the nested families to show in my schedule. So what I did was - Edit the family, then edit the nested family. Change it from Shared to Not Shared and load it back into the family it is nested in. I got the message "Can't load family because a shared version already exists." How can I get it nto shared without deleting and reloading/rebuilding the family?
Fri, Apr 5, 2013 at 7:08:23 AM | Nested Families
In the host family, edit the name of the nested family.  Now it will load.
Fri, Apr 5, 2013 at 12:17:31 PM | Nested Families
TerribleTim
Thank you WWhub, that worked great!!!
Locking nested families?
Wed, Aug 27, 2008 at 12:23:09 PM
13
nested families do not cut
Thu, Jan 14, 2010 at 11:44:55 AM
Door swings with nested families
Fri, Sep 18, 2009 at 1:41:24 PM
Hiding nested families in a project
Thu, Jan 14, 2010 at 10:21:37 AM
turning on/off nested families in host family in different views in project.
Fri, Aug 7, 2009 at 11:11:32 AM
Page generation time: 0.2166
