Forums >> Revit Structure >> Technical Support >> SO CLOSE . . YET SO FAR . . . Multiple Assemblies per sheet
Tue, Jan 31, 2012 at 4:04:49 PM | SO CLOSE . . YET SO FAR . . . Multiple Assemblies per sheet
gregroberson
gregroberson Avatar
Asssemblies seem really awesome and I would like to start using them more for my drawings now that we are finally getting into RST 2012.  Is there any way to have multiple assemblies on a sheet.  I was thinking for complicated connections and items like that.  I would like to be able to just create and assembly and place them on a sheet.  However, Revit politly informs me that I can only have an assembly placed on a sheet that specifically belongs to the assembly.  Was that clear?
Greg
Thu, Mar 29, 2012 at 7:23:10 AM | SO CLOSE . . YET SO FAR . . . Multiple Assemblies per sheet
jstewart
I would like to use Assemblies to do our Curtainwall Elevations.  Has anyone ever done this?  It does not work though because we cannot add more than one assembly to a sheet.  Even though it says you can in the Revit help.
Autodesk PLEASE fix this!!
Multiple independent sheet index for cover sheet
Tue, Feb 4, 2014 at 8:28:13 AM
Assemblies
Mon, Mar 18, 2013 at 5:46:04 PM
copying assemblies between projects
Fri, Jun 1, 2012 at 10:39:32 AM
Graphic display options assemblies
Thu, Nov 21, 2024 at 3:35:02 PM
multiple instances of the same view in sheet not supported
Tue, Dec 4, 2012 at 12:40:35 PM
Page generation time: 0.4282
