Forums >> Revit Building >> Technical Support >> Help with assigning a MATERIAL to an object
Tue, Jan 31, 2012 at 2:38:08 PM | Help with assigning a MATERIAL to an object
bmw11292
Hi, I am new to REVIT 2012 and not familiar with all the changes yet.  In previous versions I could simply click the "paint" can logo and assign pretty much anything in revit a material of my choice.  Is there a way to do this in the new version?  I tried to assign a "grass" material to a floor but when i rendered, it was just a plain grey floor with now grass.  PLEASE help me as I just cannot seem to figure this out, thanks!
Tue, Jan 31, 2012 at 2:48:12 PM | Help with assigning a MATERIAL to an object
Not that many changes in 2012.  If you were accustomed to painting, you still can but that (not a paint can image in 11 or 12 - now a soccer ball to cube) is poor practice generally.  You should be editing your type families and assign appropriate materials there.
Tue, Jan 31, 2012 at 2:49:55 PM | Help with assigning a MATERIAL to an object
bmw11292
In other words, I created a floor on the second story that extrudes from my house, and my plan is to make it a second story garden type of thing. How can I assign a grass material to my floor?
Tue, Jan 31, 2012 at 3:00:36 PM | Help with assigning a MATERIAL to an object
  1. Use a seperate floor type for that area only that has the correct material.
  2. Split the surface of your floor and assign a different material to the split area using the paint tool.
I would think that #1 is the way to do this because the floor thickness / structure willl be different.
Tue, Jan 31, 2012 at 6:10:33 PM | Help with assigning a MATERIAL to an object
bmw11292
Great, thanks!
how to know the material used in a specific object?
Mon, May 9, 2011 at 1:14:23 PM
Assigning Materials to 3D objects made with the command “Modelling-Create...”
Fri, Jun 3, 2011 at 5:57:50 PM
Components
Wed, Dec 7, 2005 at 11:53:18 AM
Apply material to object style not working.
Fri, Jun 15, 2012 at 7:33:23 AM
Material schedule not picking up materials in railing object
Fri, May 6, 2011 at 4:03:35 PM
Page generation time: 0.9639
