18 Users Online (16 Members):
Forums >> Revit Systems >> Technical Support >> 2d Line Based compnents - rotate hatch region for plan and section
12 Posts No Rating |
I have created my 2d line based component with the revit family...I used the Vertical lines for the look I needed in Plan Details,
Now i need to show the same component in Wall section but need the region to rotate with the component.
Thank you,
Timothy Livingston
Sorry but your question is unclear.
I take it that this is a 2D detail component - correct? If so, then you can use it in any view and rotate it as you choose. If this component has a fill pattern in it, then you need to understand Revit fill patterns. I suggest you read this topic "Fill Pattern Host Orientation" for drafting patterns.
If it is something else, then be more descriptive of your problem.
Plan Region not shwoing wall hatch?? |
Mon, Jan 14, 2008 at 12:03:29 PM
3-d hatch region |
Mon, Aug 11, 2008 at 10:32:33 AM
Content hatch - rotate with component |
Mon, Apr 11, 2011 at 10:22:41 PM
Masking region at section callout head. |
Tue, Jul 30, 2013 at 1:43:26 PM
Using Region (hatch) in Multiple Views |
Wed, Mar 14, 2012 at 8:41:05 AM
