25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Problem with importing objects
5 Posts No Rating |
I found many good source of rfa files and I want to use them for the project. But somehow I can't load them into Revit BUilding.... I need help.
THanks
Load family?? there isn't any more too it than that. After that its just a matter of placing the element.
What objects are you having trouble with.
5 Posts No Rating |
Oh sorry I screw up... I finally got it done. Thanks anyway
But there is one thing I am wondering about: When I insert decals (from modelling) I select a picture but it dosn't show up on the 3-d view. I wonder why?
Thanks
52 Posts No Rating |
hi,
Are you not able to see in rendred view?
Decal will not be seen in shaded or hidden mode. it will look as box with cross or so. the actual piture will be seenn only when you render it.
Regards,
HELP! importing 3D objects cant be exploded |
Fri, Nov 10, 2006 at 10:48:19 AM
Importing DWG or DXF file objects |
Wed, Jul 12, 2006 at 10:45:32 AM
Importing .3ds objects into revit OR a WORKAROUND?? |
Fri, Aug 7, 2009 at 10:23:19 AM
Importing .sat files to Revit - the ever infamous problem |
Tue, Jan 22, 2013 at 6:47:00 AM
13
Creating Objects |
Mon, Mar 8, 2010 at 9:24:52 AM
