Forums >> Revit Building >> Technical Support >> Revit to CorelDraw
Tue, Jan 31, 2012 at 3:29:35 AM | Revit to CorelDraw
spacey
I have sketched a line drawing of a celtic cross with knotwork for use on a family member's headstone.
The family want to use the design, and the text layout I included, but the Monumental Masons have asked for the indicative pdf I sent them as a Word file! ?!
I assume this is because that is what they usually get.
I thought a vector based format would be more suitable as they use Corel Draw.
It is confusing, because I cannot deal doirectly with them, but through another family membe, who stated that a vector based file was not appropriate as they were using Corel...
If someone can advise of a suitable format Revit can write to, that Corel can read, I would very much appreciate it.
Tue, Jan 31, 2012 at 12:10:30 PM | Revit to CorelDraw
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
you stated that the monument manufacturer, would like a PDF, this is the most common file to transfer. Get PDFCreator, free. Then you use it like a printer. It will create PDF's and other types of files, very handy.
Tue, Jan 31, 2012 at 5:43:14 PM | Revit to CorelDraw
spacey
No, sorry, I worded that badly. The monummental Masons have a PDF I sent them, but they have asked for a Word file.
print to file
Sun, Jun 11, 2006 at 1:57:07 AM
PHOTOSHOP DOWNLOAD
Tue, Mar 3, 2009 at 10:09:42 PM
Column in a slope and modeling a bench
Fri, May 4, 2012 at 12:33:57 PM
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
Page generation time: 1.3308
