Forums >> Revit Building >> Technical Support >> How to delete linework created by underlay
Mon, Jan 30, 2012 at 5:52:09 PM | How to delete linework created by underlay
HP11
I've attempted to use the linework tool on an underlay in my floor plan in order to show the outline of the floor plate above.  I am new to Revit and was testing this out but now I am not able to remove the linework I've created in the active plan without deleting from the model entirely.  I can adjust the visibilty settings of the linework selected but this does not seem to help in removing the linework completely from this plan which I would like to do.  Please help if you have any thoughts!
Using 2012
Mon, Jan 30, 2012 at 6:25:39 PM | How to delete linework created by underlay
mhans
3 Stars: 10 Votes
Select everything and use filter (funnel symbol)?
Motto: "No Post left behind"
Mon, Jan 30, 2012 at 6:34:25 PM | How to delete linework created by underlay
mhans
3 Stars: 10 Votes
In Linework, you are not actually creating lines but modifying the line appearance of an object. To return it to its original property, select the object/line and click "by category" option from Linework command.
Tue, Jan 31, 2012 at 8:28:43 AM | How to delete linework created by underlay
HP11
I've tried this but the objects I had originally selected to change the linework appear to still be in the floor plan view while they are actually associated with the level above.  They are not visible but when my mouse rolls over them I can select and modify.  This seems messy and worries me that an object could accidentally get selected in another view and deleted or moved.  Should the "by category" linework option fix this?  Is there a way to select the object in question and see what linework is assigned to make sure I have done this correctly?
For now I have modified the object linework in question to the "by category" and then selected as "hide in view" by element.  For now this seems to remove the linework from the active view but I would still like to understand this issue better.
Tue, Jan 31, 2012 at 9:45:57 AM | How to delete linework created by underlay
Read this chapter in your HELP:  Changing Line Styles for a View Underlay
You can use the Overhead line style for tracing underlays or define your own line style.  These lines (2D) are then part of the view and you turn off the underlay.
Display pipes - solid on current level, dashed if above
Wed, Sep 6, 2017 at 2:25:24 AM
Underlay screening %
Wed, May 10, 2006 at 11:02:36 AM
How to see the upper floor (beams,floors) in plan view?
Tue, Jun 14, 2005 at 4:37:20 AM
Underlay
Thu, Oct 11, 2012 at 8:15:33 AM
Can you save linework?
Tue, Aug 12, 2008 at 7:37:07 PM
Page generation time: 1.1362
