14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> Rendering issue - Unfinished render
5 Posts No Rating |
I have a problem with revit 2012, I used to render without any problems but this is the first time that I came through this issue. Some of the rendering stay black and i have some dot of all sort of colours like you see in the picture. Does someone tell me where is it coming ? I have render other thing just now and it's ok but for this I have this issue. So i thought it was my graphic card but not..I have one image once rendered and the other in consistent graphic display. So if someone could help me out. Thanks
Edited on: Sun, Jan 29, 2012 at 3:18:42 PM
Your pictures did not attach.
5 Posts No Rating |
Yes i'm having some issues with the uploader but here are the pictures.. follow these links. Photo 1 - http://api.ning.com/files/VVJ9HAL1Qo*YkCjAQwVcVpeR7qxWO2*fsfzMQ0Ix-Ef8jerQIxqUsIv-6kqdJ0BcwG2tguHRczGJPbRvcU8Te9aQu5JF7OOt/issue1.JPG
Photo 2 (Consistent Graphic Display) - http://api.ning.com/files/xCwNojTvjrNYAFMLaITbZeFEKueLLTAY3rexZ7WRck-DEO-CLzwI*RbRGoiraCMVnxhpgEnNuMwZPger-meItZOhppXqOjZX/issue2.JPG
I don't understand why some people are having trouble uploading images. If they are staying within the limits, then I think the issue may be their operating system. Please tell us about your system and the file type / size that you are trying to attach.
It looks like you have some different lighting in your room, have you used all of those fixtures before?
5 Posts No Rating |
I have windows 7 ultimate, with an Nvidia Gt 240 and 4gb ram and 64 bit motherboard architecture. I'm running a laptop, Yes I have already used these lighting before, this is the first that I've come across this problem...
5 Posts No Rating |
The images was jpeg format of 133kb and 62kb. normally the file size is 2mb. Check on the link below : http://api.ning.com/files/WQFPn1f3G9Q*YQCiuDdzrKlwTzQYpnbJ4xXGrzHdN5j0mNsZDXPorIsztl8*YQwgAX-K4zLOeq4CDyN3wLpkRqRMsIrl1VjH/uploadissue.JPG
There is something strage with you jpg's. I can't even upload that. It is supposted to be attached.
Try using screenhunter free to capture a gif image and upload that.
5 Posts No Rating |
even for gif it is the same, using sreen hunter...
09' Rendering Issue |
Wed, Jun 3, 2009 at 4:22:51 PM
11
Render Issue |
Mon, Aug 24, 2015 at 7:01:38 AM
issue with rendering |
Tue, Nov 24, 2009 at 6:18:48 AM
Revit Custom Materials Rendering Objects invisble |
Mon, Mar 14, 2011 at 10:42:55 AM
13
Revit render or 3ds max design render? |
Sun, Jan 4, 2015 at 10:19:29 AM
