Forums >> General Discussion >> Wishlist >> Development for Section box command in Revit
Sun, Jan 29, 2012 at 4:22:24 AM | Development for Section box command in Revit
faisalhosny
Can we be able to make a section like the attached one (Done in 3ds Max) by using a section box command in Revit the development for the section box as I dream to use more than one section box at the same time and each section box can be applied to a certain type of elements, so we can keep the cutting line for the walls in the background higher than the cutting line for the other walls and it will be nice to exclude some elements like furniture or some structural elements like  I beams to keep it appeared out of the main section box, I hope I explained clearly what I want to say thanks for your great forum.
Mon, Jan 30, 2012 at 3:25:01 PM | Development for Section box command in Revit
mhans
3 Stars: 10 Votes
Yes.
Motto: "No Post left behind"
Fri, Apr 20, 2012 at 10:43:50 AM | Development for Section box command in Revit
designer619
So, now that we know that we can do this, could one give insight as to how to control what is cut and what is not cut by the 3d section view?
Thanks!
Also, that is a beautiful rendering!
Fri, Apr 20, 2012 at 12:17:11 PM | Development for Section box command in Revit
Everything in the view is cut by the section box limits.
Fri, Apr 20, 2012 at 3:50:03 PM | Development for Section box command in Revit
designer619
Well that is unfortunate. hmm, revit 2014 maybe??
Section box in Section??
Sat, Dec 10, 2011 at 10:23:01 PM
13
3D Section Box
Thu, Nov 1, 2012 at 11:00:40 AM
"True" Shadows in Section Box (Section Perspective?)
Tue, Nov 15, 2011 at 6:02:21 PM
Attach Building Section Heads to Section Box
Mon, Sep 21, 2015 at 4:53:57 PM
How to indicate section box in plan view?
Mon, Jun 23, 2014 at 6:56:41 AM
Page generation time: 5.7058
