Forums >> Community >> Newbies >> area color schemes
Fri, Jan 27, 2012 at 10:09:42 AM | area color schemes
husam3
there is any way to make color schemes half tone so i can see through the master plan ?
Fri, Jan 27, 2012 at 10:52:00 AM | area color schemes
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The color schemes shouldn't cover any of your plan up.
Fri, Jan 27, 2012 at 10:57:45 AM | area color schemes
husam3
i know but i made an area plan to image so there is no walls or plan and the color schemes is solid i cant see through it the image is that possible on revit ?
Fri, Jan 27, 2012 at 11:01:32 AM | area color schemes
husam3
there is a pic to explain what i mean
Edited on: Fri, Jan 27, 2012 at 11:03:39 AM
Fri, Jan 27, 2012 at 11:59:46 AM | area color schemes
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Oh I see.  I don't think there is a way to just have it shaded but I am not positive on that.  You could try using a different fill pattern such as diagonal lines so that it would show through.
Fri, Jan 27, 2012 at 12:06:27 PM | area color schemes
Don't use an area plan.  Simply a transparent fill with text.
Fri, Jan 27, 2012 at 12:07:13 PM | area color schemes
husam3
i tried to made cross up with big pattren but it not shown through .. thank you
Fri, Jan 27, 2012 at 2:36:28 PM | WWHub
husam3
Quoting WWHub from 2012-01-27 12:06:27
sorry i just saw your comment ,so you mean fill region ?
Color Schemes - Revit 2009
Fri, May 8, 2009 at 12:02:04 PM
Area Schedules and Area Schemes - Revit 2019
Tue, Apr 2, 2019 at 7:41:56 AM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Color Schemes
Fri, Dec 14, 2007 at 8:06:53 AM
Color Schemes
Wed, Jun 3, 2015 at 3:15:18 PM
Page generation time: 2.3054
