11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> rendering with revit
Is there a way to put balck line around different materials in your rendering revit?
A black line around different materials? What exactly do you mean?
if you are referring to black edged surfaces you can export your scene in hidden line, then render and export. take both images and compile them in photoshop, blend the layers using multiply. If you dont use photoshop and this makes no sense to you I am sure I can find a quick tutorial. it only takes a couple minutes.
If you do have a tutorial I would like to take a peek at it also!
here is a quick explanation of multiply in photoshop
http://henrik.nyh.se/2008/09/photoshop-multiply
THANKS
revit rendering |
Thu, Oct 14, 2010 at 8:33:24 AM
Revit MEP 2009 Rendering |
Thu, Mar 5, 2009 at 8:35:55 PM
What is the best revit/rendering engine combo? [ 1 2 3 ] |
Tue, Feb 3, 2015 at 9:40:52 AM
31
Revit 2009 Rendering Problem(Black screen) [ 1 2 ] |
Mon, Apr 1, 2013 at 2:45:28 PM
27
Realistic Rendering [ 1 2 ] |
Thu, Aug 4, 2011 at 2:30:37 PM
25
