5 Users Online (3 Members):
Forums >> Community >> The Studio >> walls
i have a wall that is 2 x 8 joining a wall that is 2 x 4 these walls are not perpendicular so they are continuous with the wall getting thinner. my question is how do i make the gyp. board wrap around the end where the wall gets thinner as it should?
you will need to go to the properties of the wall and structure---> edit and check your "default wrapping" at inserts and ends...
HTH
i don't think you understand what i meant i have attached the example
sorry, i can't view your file, the IT department is implimenting this new web block system... need to let them know today and will check your file...
Since the two walls are "joined" I don't think the wrapping can be automatic since where the join is is not the "end" of the wall.
I don't think what you are looking for is possible without a work-around.
I have a walltype defined as only a layer of 5/8" gyp for these oddball things or you could just use linework. We don't have a ton of these types of conditions so it is not a big deal for us.
HTH
Tom
Attaching Rails to walls |
Thu, Aug 13, 2009 at 12:59:42 PM
Walls |
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool? |
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls. |
Sun, Dec 14, 2014 at 4:58:35 PM
