19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Bent Steel Plate
I'm looking for a parametric bent steel plate, one that I can control the length, length of legs, thickness of the steel and maybe a bonus of a radius of bend. Anyone have anything like that the could share?
If you are talking about a detail componet, why not start with the light gauge angle that comes in your library? Leg lengths are type driven and you could add a thickness parameter.
I just found that in my library so I'm going to manipulate it as you said. Any pointers, threads or tutorials you can point me towards for adding angle parameter so I can adjust the angle of the legs if needed?
I am doing it as a detail component by the way.
I have pointed to this pointer often: In the Revit Help pulldown is the link to the "Documents on the web" where you will find the families guide......
Revit 2019 - Steel Plate question |
Wed, Sep 25, 2019 at 1:18:29 PM
plate not saving |
Fri, May 2, 2025 at 1:22:19 PM
Steel beam to steel/concrete column fixture (Noob question) |
Wed, Feb 27, 2013 at 3:18:10 PM
Creating Folded steel plate stair with concrete tread |
Wed, Sep 5, 2012 at 1:07:47 PM
Detailing a Beam Saddle at Valley Beam |
Wed, Jan 26, 2011 at 12:15:21 PM
