Forums >> Revit Building >> Technical Support >> Surface Patterns in Perspective
Thu, Jan 26, 2012 at 4:24:58 PM | Surface Patterns in Perspective
bigworm917
I have a few perspectives that I use in Revit 2011 as a concept tool. The perspectives are in the "Shaded with Edges" visual style. The surface patterns for the floor and walls show correctly in the foreground; however, the patterns start to disappear or fade as you look further into the perspective. Is there a way to force the perspective to show all the surface patterns all the way into the background? Thanks for your time.
Fri, Jan 27, 2012 at 7:04:34 AM | Surface Patterns in Perspective
No.  Only a rendered view will give you what you want.
No Surface Patterns in Perspective
Thu, Feb 1, 2007 at 4:55:53 PM
Building Material Patterns disapear at tight perspective angle
Sun, Aug 10, 2014 at 3:25:39 PM
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:50 PM
Surface Patterns
Wed, Mar 4, 2009 at 11:24:15 AM
Existing Phase Surface Patterns visibility
Tue, Nov 14, 2006 at 6:37:24 PM
Page generation time: 0.1361
