Forums >> Revit Building >> Technical Support >> Stair Showing Below Mezz Slab
Thu, Jan 26, 2012 at 9:23:25 AM | Stair Showing Below Mezz Slab
cboersen
I have a stair going from a mezzanine down to the main level.  The opening for the stair is shorter than the stair is long (ended the opening when head height cleared).  When I look at this stair on the mezzanine plan the whole length of the stair shows even though the end entends under the mezzanine slab.  It acts as though the mezzanine slab is trasparent, but it is not.  How do I get the stair to stop displaying as it goes under the mezzanine slab?
Fri, Jan 27, 2012 at 7:57:03 AM | Stair Showing Below Mezz Slab
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do you have the floor below set as your underlay?
Fri, Jan 27, 2012 at 8:02:48 AM | Stair Showing Below Mezz Slab
cboersen
Good thought, but no.  My underlay is set to "none"
Fri, Jan 27, 2012 at 8:11:37 AM | Stair Showing Below Mezz Slab
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is your visual style set to wireframe? I've also seen this answer in a previous post by WWHUB....
Do you have floors?  and are they turned on?Are the floors over-ridden to transparent in view?
A quick check is just to goto the view tab, select floor plan, uncheck do not duplicate and create a new floor plan.  This will not have any mistakes in its settings.
Fri, Jan 27, 2012 at 8:21:10 AM | Stair Showing Below Mezz Slab
cboersen
The simplist of things will get you every time - it was set to wire frame.  Setting to hidden line fixed it.  Thanks for the help and the other suggestions.
Stair to Slab Connection
Tue, Jun 5, 2007 at 3:52:46 PM
how to connect monolithic stair to f.c. slab
Fri, Apr 17, 2009 at 2:38:25 PM
Showing walls from the bottom of slab
Tue, Feb 9, 2010 at 10:40:40 AM
Creating concrete stairs from raised exterior slab
Sat, Oct 25, 2014 at 10:26:43 PM
Slab not showing in 09
Fri, Jun 20, 2008 at 8:21:54 AM
Page generation time: 0.2259
