29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Workaround-Project to Family
So I have built a container structure...ie One Steel Box. and it was created as a project. (it has walls and a ceiling and a floor so you can punch it with windows etc..) Ill post here for anyones free use. but now I want to turn it into a family, so that I could have them in the components menu like a tree or a car, but can this be done? I try the save as command, go to the family part, but then it doesnt seem to do anything...in fact it became a circular baluster named container...
Because you didn't create that as in-place and you have walls, ceiling and floor the best you can do is a GROUP and save that group, now you can load that group in other projects when you need.
If you really want it to be a family and it's not parametric, export it as 3D dwg, create a generic family and import your 3D dwg using Import CAD.
Thanks a lot, those are both great suggestions.
M
Can you re-post this thread with the Subject: Workaround-Project to Family? The idea is to easily find it in the Search Tab. The contents of your re-post would probably like:
Problem: Objects created in a project file (.rvt) converted to a Family (.rfa) (Or anything that suits your taste.)
Workaround: (You'll summarize here the best solution(s) that worked for this particular scenario as suggested in the thread. You can even add an image as supplement.)
Note: See my post yesterday entitled "Workarounds"
Phantom doors in project and COBie |
Sat, Oct 24, 2015 at 11:05:08 AM
2012 Family Creation |
Tue, May 31, 2011 at 10:05:27 AM
Why the bad quality in family models? |
Fri, Jan 22, 2010 at 10:06:32 AM
How to use a v8 Family in v7? |
Wed, Aug 10, 2005 at 1:47:35 PM
Nested Family Parameters in Project Bug? |
Thu, Nov 13, 2014 at 12:31:00 PM
