Forums >> Community >> Newbies >> Change material on wall
Wed, Jan 25, 2012 at 9:10:07 AM | Change material on wall
JoBrowns
I need a textbook-style answer to this question: If you want to change the material on a stacked wall, what do I need to change? Do I change the Wall type of the stacked wall? Or the structure of the stacked wall? Or the structure of the associated wall within the stacked wall? I've had difficulty understanding the difference between wall type and wall structure.
Wed, Jan 25, 2012 at 9:24:35 AM | Change material on wall
A stacked wall is just that.  Stacked individual wall types.
I always suggest that you alter individual wall types if you want a change of materials.  I suggest you just don't "paint" a finish.  Materials are typically represented differently in thickness and in sectional views.  Painting will not to this.
So my suggestion is to:
  1. unstack the wall and replace the wall type with a new wall type.
  2. Redefine the wall type in the stack (and rename if appropriate.)
  3. Create a new wall type and create a new stacked wall using this type.
Thu, Jan 26, 2012 at 12:47:24 AM | Change material on wall
JoBrowns
Sorry but you didn't answer my question. You are correct in the practical sense. ButpPlease read my question- it's a theoretical, textbook question. It's not "how to change the materials, per se. It's what is it that you call it the thing that you change - the structure or the type? What is it that you are changing, exactly??? Please read the question carefully. Thanks.
Many thanks
Thu, Jan 26, 2012 at 4:18:36 AM | Change material on wall
Dafpfy
3.5 Stars: 11 Votes
meaning you change the material in the wall type that you want to change,
without changing anything in the stacked wall directly,
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Thu, Jan 26, 2012 at 7:15:41 AM | Change material on wall
I guess you really didn't read my answer.
Curtain Wall Window Material
Wed, Dec 15, 2021 at 2:04:35 PM
Changing material on a Curtain Wall
Tue, Apr 21, 2009 at 6:30:19 AM
Can't Change Hatch Material On Wall
Mon, Oct 14, 2019 at 11:01:30 PM
how to change one 1 curtain wall material
Fri, Sep 5, 2014 at 4:06:44 PM
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
Page generation time: 3.4977
