Forums >> Revit Building >> Technical Support >> Import full Civil 3D 2012 model in Revit Architecture 2012
Tue, Jan 24, 2012 at 4:20:19 AM | Import full Civil 3D 2012 model in Revit Architecture 2012
nko87
I have a full Civil 3D 2012 model with toposurface and streets. I want to import this model Revit Architecture 2012, but when I use:
1. Import CAD - it imports only part or all of the toposurface but without any streets
2. Using official extension Road and Surface of Autodesk - it imports with many problems and finaly there is almost the same results as 1)
Please help me Smile
Wed, Jan 25, 2012 at 2:27:40 PM | Import full Civil 3D 2012 model in Revit Architecture 2012
mhans
3 Stars: 10 Votes
I don't have the right answer for you but this will get you out of the 'Posts with 0 reply'. Did you import using "Create from import"? It only takes the x,y,z coordinates and will not import surfaces. Did you save the 3d civil file to a 3D Autocad and import it via Insert Tab - Import CAD?
Motto: "No Post left behind"
Wed, Jan 25, 2012 at 4:12:48 PM | Import full Civil 3D 2012 model in Revit Architecture 2012
nko87
Ok, now I`m clear that nobody understand what I want.
I`m looking for a way to put many roads/streets on topografic surface which is with some slope, so that and the streets.
I found the way to build everything correctly in Civil but I couldn`t find any way to import the model as surface.
I`ve tried to export it as dxf and create toposurf - but nothing good happened...
Everything what I need is to create my toposurf with so many streets, roads, pavements and so on on a slope toposurface.
The only thing which I`ve found is "Siteworks for Revit" - http://www.eaglepoint.com/products/siteworksforrevit/index.html - but it is paid.
Edited on: Wed, Jan 25, 2012 at 4:17:15 PM
Wed, Jan 25, 2012 at 4:55:24 PM | Import full Civil 3D 2012 model in Revit Architecture 2012
mhans
3 Stars: 10 Votes
What you can do is just export your Civil 3D drawing to a dwg format and import it to Revit via Insert Tab - Import Cad. You can also use link in case you need to edit your topo later on. You won't be able to edit the imported 3D objects.
Thu, Jan 26, 2012 at 12:59:09 AM | Import full Civil 3D 2012 model in Revit Architecture 2012
nko87
How to export it to dwg format after that that Civil 3D file is DWG?! What did you mean export in dwg!?
Thu, Jan 26, 2012 at 6:23:35 AM | Import full Civil 3D 2012 model in Revit Architecture 2012
4 Stars: 205 Votes
Check this: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13734321
Importing autocad civil data! Whats best for Revit 2012
Tue, Jul 23, 2013 at 7:44:02 AM
Import 3D .dwg model in Revit Architecture 2012
Tue, Oct 9, 2012 at 6:39:39 PM
Linking a civil 3D CAD file to Revit Architecture 2012
Thu, Jan 12, 2012 at 6:48:02 PM
revit structure 2012 add-in "integration with civil 3d": routing error?
Wed, Jan 25, 2012 at 2:56:13 AM
Using 3D Studio Objects in Revit Architecture 2011
Tue, Sep 20, 2011 at 12:09:53 AM
Page generation time: 1.9466
