Forums >> Revit Structure >> Technical Support >> Framing add-on
Mon, Jan 23, 2012 at 4:46:40 PM | Framing add-on
idraw38
In Revit 2011 how does one get this extension into the ribbon in Revit architecture? I downloaded it OK.
Mon, Jan 23, 2012 at 5:09:05 PM | Framing add-on
mhans
3 Stars: 10 Votes
I'm not sure if 2011 supports the framing extension. If it does, you'll find a tab that say Extensions.
Motto: "No Post left behind"
Mon, Jan 23, 2012 at 7:53:42 PM | Framing add-on
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yes 2011 did support the Wood Framing Wall Extension.
After 'installing it ', it should show up on the ribbon.
I also tested the framing extension extensively in 2011.
Needed ALOT of work and I could not get in touch with the developer.
The application is about 50% complete and pawned off as a value added feature.
Go Autodesk.
See review and video in link below.
http://revitrocks.blogspot.com/2010/01/revit-wood-framing-walls-extension.html
Adding length parameter to framing tag
Sun, Jul 18, 2010 at 4:19:26 PM
Framing Add-in
Wed, Nov 11, 2009 at 10:10:41 AM
Wood Framing Walls Extension; Locating and External framing
Fri, Jul 31, 2015 at 8:03:14 PM
wood framing extension
Mon, May 7, 2012 at 3:23:48 PM
Framing Plan
Tue, Jan 3, 2006 at 4:10:28 PM
12
Page generation time: 0.2513
