Forums >> Revit Building >> Technical Support >> Room Problem
Sun, Jan 22, 2012 at 11:59:22 PM | Room Problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hey guys,
I had made this room bigger but now the room tool wont go to the full size of the room. I try to delete and redo but it
just does the same thing... No room seperation lines or anything.
http://screencast.com/t/jSoQ5qGCv
Revit 2018........
Mon, Jan 23, 2012 at 12:24:13 PM | Room Problem
Is this room hosted on this level?
Cut a section through that bottom wall and post that with everything on.
No Design Options - right?
Basement wall doesn't cut this room and hidden in view - right?
Mon, Jan 23, 2012 at 12:24:53 PM | Room Problem
mhans
3 Stars: 10 Votes
Is there a wall below it? Can you show a section thru that room? It seems to me that there's an invisible wall or a wall above your cutting plane that defines the smaller area.
Motto: "No Post left behind"
Mon, Jan 23, 2012 at 4:02:55 PM | Room Problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
There is a wall below but not in the way...here are some pics..
http://screencast.com/t/VRCShFm5
http://screencast.com/t/artXbJrJcn
Think I found the problem if you look on this section you can see 2 little lines near the ceiling and near the ridge they are
exposed rafters I made out of a wall and just edited the profile. Any idea how to fix it besides delete the wall(rafter) looks
like it is cutting into the wall a bit tho
http://screencast.com/t/pvfJ1XvxxNop
http://screencast.com/t/32V6ip8yw
here is what the house looks like so you can see the exposed rafters.
Revit 2018........
Mon, Jan 23, 2012 at 4:22:25 PM | Room Problem
mhans
3 Stars: 10 Votes
It looks like you have not drawn-in the floors. If you don't have a floor, you will confuse Revit when defining the room.
Mon, Jan 23, 2012 at 4:52:29 PM | Room Problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Was that little feature wall thing. So all good Yeah I have to put the floor in client keeps changing there mind....always the way.
Thanks for your help guys if I didnt cut a section through there wouldnt of noticed
Revit 2018........
Mon, Jan 23, 2012 at 9:09:06 PM | Room Problem
Novelh
If that is the case you can always select the wall and uncheck "room bounding"
room areas, room separations
Mon, Jun 2, 2008 at 8:19:42 PM
BIG curtain wall room bounding problem!!
Mon, Dec 14, 2009 at 9:31:31 AM
Help. Room Tag Problem
Wed, Nov 28, 2007 at 8:09:48 AM
Room Boundary Issue [ 1 2 ]
Tue, Sep 11, 2012 at 12:46:42 PM
21
Fri, Jul 28, 2017 at 4:03:50 AM
13
Page generation time: 1.0865
