Forums >> Revit Building >> Technical Support >> Roof / Wall core problem
Sun, Jan 22, 2012 at 8:07:39 PM | Roof / Wall core problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hey guys been playing around with this for a while now and I'm not sure how to fix it. as you can see from the pictures.
When I choose extend to core (so my roof pitches from the stud wall and not the brick) it works fine for the house but
when I try do extend to core on the garage walls (single / Double brick) there is a problem and either it doesnt cover all the
brick or it puts it at a different level from the house roof. Is it something I change in wall structure?
Thanks.
http://screencast.com/t/VGrCfgZ1
http://screencast.com/t/QjgvuCDcLgK
Revit 2018........
Mon, Jan 23, 2012 at 12:32:05 PM | Roof / Wall core problem
mhans
3 Stars: 10 Votes
Bring your your outline to the exterior face of your wall.
Motto: "No Post left behind"
Mon, Jan 23, 2012 at 4:26:54 PM | Roof / Wall core problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Then the problem is that the wall is not extended to core and then the section will be wrong.
This house doesnt have eaves so I do extend to core then add 150mm for eave (to cover brick and cavity)
when I get to the garage single brick wall because it doesnt have the same overhang as the wall is a different thickness
and has a differnt wall core it doesnt work....
Revit 2018........
Mon, Jan 23, 2012 at 4:43:47 PM | Roof / Wall core problem
mhans
3 Stars: 10 Votes
This is what I mean. You can create a level and just attached the top of wall to that level if in case your wall does not attached to the roof.
Mon, Jan 23, 2012 at 4:54:44 PM | Roof / Wall core problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Can you do that with a brick veneer wall and cut a section to see if it is pitching from the stud and not the brick? Cause
that is my problem if i just draw around the edge.
Revit 2018........
Mon, Jan 23, 2012 at 9:01:45 PM | Roof / Wall core problem
Novelh
You have to attach the walls to the roof. The one on the right is attached and the one on the left is not.
Mon, Jan 23, 2012 at 9:42:20 PM | Roof / Wall core problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
It wont allow me to attach the walls to roof as it looks like the "right" one in the picture.
If I just draw a line around the edge then it does work fine...but in section it is wrong and will pitch off the brick work
and not the stud wall like it is ment to. Thats why I need to extend to core so the section is correct
Revit 2018........
Mon, Jan 23, 2012 at 9:54:12 PM | Roof / Wall core problem
Novelh
The core will extend to the roof if you attach the walls to the roof. I'm not sure if the image I uploaded was visible in my last post.
Mon, Jan 23, 2012 at 10:07:14 PM | Roof / Wall core problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
yeh that worked. I did entend to core then allined the lines with the outside of the walls. But still a problem with the roof
line. As there is a garage with single brick and piers im guessing that is the problem. I will attach some pic links for you
to look at. Also you pic didnt load. I use Jing.
http://screencast.com/t/1W3SlkKngm
http://screencast.com/t/bdMmYH0K
Revit 2018........
Tue, Jan 24, 2012 at 5:33:55 PM | Roof / Wall core problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
I think its to do with the wall core. As there are 3 different types of external walls which is causing the problem....anyone
got any ideas?
Revit 2018........
Wed, Jan 25, 2012 at 7:53:59 AM | Roof / Wall core problem
#11
You have some strange roof conditions shown there.  Take a good look at your offset form roof on all edge sketch lines and recheck your slopes.
Wed, Jan 25, 2012 at 11:34:28 AM | Roof / Wall core problem
#12
mhans
3 Stars: 10 Votes
In this case, you have to show us the rvt file.
Sun, Jan 29, 2012 at 4:16:43 PM | Roof / Wall core problem
#13
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
can you give me your email as the file is 15MB. Thanks for your help.
Revit 2018........
Sun, Jan 29, 2012 at 9:40:56 PM | Roof / Wall core problem
#14
mansell5
3.5 Stars: 4 Votes
gday jamie,
did you try swapping out walls , do your roof, then change walls back to single leaf etc.
it works for verandahs with no walls only piers.
ie put in temporary walls to help revit work out the roof with consistant pitching points etc,
then swap out your temporary wall with required wall as required.
cheers
mansell
Mon, Jan 30, 2012 at 4:21:21 PM | Roof / Wall core problem
#15
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
hey mate, awesome idea I didnt think of that. Unfortunatly didnt work because the house has no eaves and when we change
it back to the single skin brick wall then it has an overhang.
Revit 2018........
hiding core elements in a wall section
Fri, Jun 23, 2006 at 1:07:58 PM
Stacked Walls - how to set wall core
Mon, Apr 20, 2015 at 7:33:52 AM
Stacked Wall Core
Thu, Jan 7, 2010 at 12:55:26 PM
Roof Pitch issue
Wed, Oct 7, 2015 at 8:21:16 PM
Sloped Roof Edge
Tue, Jan 17, 2006 at 8:57:29 AM
Page generation time: 1.8269
