Forums >> Community >> Newbies >> baluster material
Sun, Jan 22, 2012 at 7:55:28 PM | baluster material
troysmithfreak
4 Stars: 11 Votes
newbie question here, but i can never find where i can edit the material of the baluster. i can for everything else in the stair (tread, riser, stringer, railing) but if someone could point me where to find where to change it so im not stuck with bland grey balusters. btw im using RAC 2011, thanks!
Sun, Jan 22, 2012 at 9:55:32 PM | baluster material
4thAngel
4thAngel Avatar
Hi,
Firstly the Baluster has nothing to do with the Stairs, it is part of the Railing Family that Revit just adds it for fun.
Step 1 - Find the Baulisters name.
Click on the railing.
Click the edit type button in the properties window (to your left I am assuming).
Click the Edit Button next to Baluster Placement
In the main patten window it has a list of Baluster Familys. Study the patten and take note of the names.
Close that window
Step 2 - Find it and set the material
Scroll down in the families tree (should be below the properties window) to railings and find the Baulister. Click the plus sign infront of it's name.
Then right click on the Baluster type and go to "type properties".
In there you should see "Materials and Finishes".
Hope this helps,
J
rail 1 and baluster heigth
Tue, Nov 8, 2011 at 10:40:22 AM
custom baluster with decorative piece not staying equal 2019
Thu, Jun 14, 2018 at 1:54:47 PM
Need help! Custom baluster
Mon, Apr 20, 2015 at 7:40:11 AM
Baluster panels & Materials
Thu, Oct 8, 2009 at 7:33:47 AM
Change baluster placement material
Wed, Apr 15, 2009 at 12:30:14 PM
Page generation time: 0.2117
