Forums >> General Discussion >> Revit Project Management >> Ghost in the Machine
Fri, Jan 20, 2012 at 6:24:03 AM | Ghost in the Machine
tmassey
tmassey Avatar
I am finding that Revit is both a boon and a detriment to finalizing or creating projects. As per example. I worked late last night cleaning up and adding annotation to the floorplans. I opened the same ground floorplan this morning and all of my grids are over top one another with some showing grid bubbles in the middle of the plan.
Text leaders are off the mark etc.
It seems like I am doing more housekeeping with Revit than AutoCAD.
Using Revit Architecture 2012
Fri, Jan 20, 2012 at 8:01:45 AM | Ghost in the Machine
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I can't say that I have ever had that problem. Revit has always worked amazing for me and once learned is much better than AutoCAD.  You must have somthing weird going on in your specific project.
Fri, Jan 20, 2012 at 8:41:03 AM | Ghost in the Machine
tmassey
tmassey Avatar
I have imported MEP and Struc models linked into my arch. View template created to hide their annotation. I am consistently turning or hiding itmes bu that should not have an effect on my anno I have no idea why my grids are doing this. I am pinning everything.
Fri, Jan 20, 2012 at 9:01:11 AM | Ghost in the Machine
Are you linking their models or or you using a view?  If you only link their model, you don't have to hide their annotations except for levels and grids.
Ahh... and you said imported..... Does that mean the MEP & Struct are CAD?  You don't say they are Revit.
Your not changing the linked files - right?  Just reloading.
Mon, Jan 23, 2012 at 9:54:25 AM | Ghost in the Machine
tmassey
tmassey Avatar
yes I have linked the rvt Consultants into our model. I would not change or revise the consult models. It is just weird that my anno in my model changes on its own.
Ghost in the Machine II
Thu, Jan 26, 2012 at 9:51:02 AM
How to delete Ghost Windows in the Model?
Mon, Apr 28, 2014 at 2:56:19 PM
Perspectives printing all grayed out!!!
Tue, Mar 18, 2014 at 1:49:16 PM
Hypothetical Revit Dream Machine
Wed, Oct 5, 2005 at 12:30:09 PM
Windows below only show when Ghost Surfaces is turned on?
Thu, Feb 2, 2012 at 4:44:00 PM
Page generation time: 2.9354
