9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> bring to front/send to back?
7 Posts No Rating |
I've got a number of renderings that I want to layer in a certain order on one sheet. Is there a way to adjust the position of views on a sheet?
i.e. bring one to the front and send another to the back?
I can't say if this will work or not as i haven't investigated it. But i'd say that it would make sense that the layering would be effected by what order you place the renderings on the sheet. That is the first rendering would be at the back. So if you place them on the sheet in the right priority it should work. Alternatively you could export the rendering to a JPG and then load it back in and place them on the sheet that way they should come up with priority boxes at the top of the screen.
Hope this helps,
Chris.
Regards,
Chris.
7 Posts No Rating |
I've already tried placing them on the sheet in different orders, but it always comes out the same. I'll try placing jpg's, thanks for the tip.
edit: I just realized that the renderings do overlay in the order placed, but I also have 2 shaded line drawings which always overlay on top of the renderings (also in the order placed)...but I want them behind!!!
Post edited on 2004-04-30 09:50:20
1 Posts No Rating |
As of 2011 it does work based on the order that the images are placed on the sheet.
Has this been addressed in r2014? Whithout really trying all the possibilities, I deleted and re-inserted overlapping views on the sheet in the desired order, and it seemed to work. these were views, not renderings, they seemed to "layer" in the desired order.
BRING TO FRONT/SEND TO BACK |
Fri, Dec 9, 2011 at 7:58:01 AM
Send to back/bring to front |
Sat, Aug 13, 2016 at 2:20:22 AM
Bring To Front |
Thu, Mar 5, 2009 at 12:54:53 PM
Title Sheet text sent to back? or transparent? |
Wed, Mar 4, 2015 at 3:25:00 PM
BRING TO FRONT COMMAND FOR REVIT? |
Tue, Nov 25, 2008 at 10:40:32 AM
