Forums >> Revit Structure >> Technical Support >> Revision Cloud Goof!
Thu, Jan 19, 2012 at 5:38:42 PM | Revision Cloud Goof!
Wildcat7
Wildcat7 Avatar
Was wondering if anyone has made this mistake ... in the sheet issues/revision box I forgot to uncheck the "Per Project" and check "Per Sheet" instead ... now I need to go back and fix the revision tag numbers.  Has someone ever done this?  How did you fix it?
I've tried by deleting all the revision clouds in the project, then going back to add the clouds per sheet mode ... but the revision tag don't show the number ... so I'm stuck!  Any suggestions?
Fri, Jan 20, 2012 at 3:58:10 AM | Revision Cloud Goof!
gebber
gebber Avatar
5 Stars: 4 Votes
I'm not sure I fully understand the problem but if I'm correct you'd like to change the sheet / project information.
Go to;
Manage,
Project parameters,
Select the desired parameter and go to modify
Change the catagory,
Make you choice between Sheet and Project information,
If the parameter has to be sheetbased and you have to change it per sheet you can make a drawing schedule.
I find it easyer to change the information in the schedules.
Hope this info could be of any help.
Fri, Jan 20, 2012 at 8:39:14 AM | Revision Cloud Goof!
You didn't need to delete anything.  Simply pick the cloud and change its properties to the right revision.
Revision cloud closes revit
Fri, Sep 28, 2012 at 10:47:52 AM
Hiding a Revision in the Revision Schedule
Thu, Nov 21, 2013 at 3:04:51 PM
Revision Cloud graphics
Mon, Aug 24, 2020 at 7:00:24 AM
Revision cloud parameters
Mon, Feb 25, 2008 at 7:53:53 PM
Revision cloud
Tue, Sep 2, 2008 at 9:35:26 AM
Page generation time: 0.0578
