Forums >> Revit Building >> Technical Support >> Stair nosing
Tue, Jan 17, 2012 at 12:23:34 PM | Stair nosing
jarosa
jarosa Avatar
4 Stars: 5 Votes
Stair nosing shows in section, 3d and elevation ... but not in plan. What do I do to make it show in plan?
Tue, Jan 17, 2012 at 2:05:15 PM | Stair nosing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are your stairs not showing at all?  Can you show a pic of what is happening.  Make sure your visability graphics your stairs are checked on.
Tue, Jan 17, 2012 at 2:50:58 PM | Stair nosing
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Actually the nosing probably IS showing in plan but it's wonkie.
See image.
Try using reference planes to show where the linework is. Then compare the plan to the section.
Stairs definately have their issues as far as creating an 'accurate' facsimilie of what really would be the stair.
Specifically when you 'end with riser'. Look at the top of the stair and compare the plan to the section.
There are weak work arounds.
The monolithic stair works much better.
Tue, Jan 17, 2012 at 3:11:45 PM | Stair nosing
mhans
3 Stars: 10 Votes
Are you looking for the line of nosing as hidden on plan?
Motto: "No Post left behind"
Mon, Jan 23, 2012 at 12:58:40 PM | Stair nosing
jarosa
jarosa Avatar
4 Stars: 5 Votes
Ok I'm back.
Nosing on sides of stair shows in elevation but not in plan????
Edited on: Mon, Jan 23, 2012 at 12:59:39 PM
Mon, Jan 23, 2012 at 1:10:14 PM | Stair nosing
You mean the hidden riser line doesn't show.  The edge of the nosing is the tread edge and Revit will not show the hidden riser line.  If you want that, then you will have to add it.
Mon, Jan 23, 2012 at 1:35:42 PM | Stair nosing
jarosa
jarosa Avatar
4 Stars: 5 Votes
Not the hidden riser line.
I selected the "Apply nosing Profile: Front, Left and Right" in the type properties. No show on left and right in plan.
Mon, Jan 23, 2012 at 1:50:17 PM | Stair nosing
mhans
3 Stars: 10 Votes
Sorry, no nosing will show left, front or right on plan view.
Mon, Jan 23, 2012 at 1:59:31 PM | Stair nosing
jarosa
jarosa Avatar
4 Stars: 5 Votes
Figured. No big worry but ..... ???
Mon, Jan 23, 2012 at 2:27:10 PM | Stair nosing
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Stairs have a few flaws.
No doubt about it. . . . . and no changes / improvements in 3-4 years at this point.
The first thing I tell my students is "Do not get caught up in stair and curtain wall details".
REVIT has some short comings in those areas that may or may not ever get addressed.
Stair Nosing
Fri, Dec 2, 2016 at 2:01:57 PM
Stair Nosing Profile Help
Thu, Feb 21, 2008 at 8:29:59 AM
Monolithic Stair Radius nosing?
Fri, Jan 30, 2009 at 2:10:43 PM
Simple Stair Nosing error
Thu, Mar 5, 2015 at 9:15:24 PM
stair nosing
Mon, Jan 30, 2006 at 2:16:45 PM
Page generation time: 0.3313
