22 Users Online (20 Members):
Forums >> Revit Structure >> Technical Support >> vertical bracing problem / bug
Hi, i have found an annoying problem / error in revit 2012 which i have no idea how to solve, I model vertical bracing the correct way by using a framing elevation then using the bracing tool to model my vertical bracing.
The problem occurs when in a plan view and my detail level is set to course. In a course plan view the vertical bracing shows up has a dash line off set from the grid line which is correct. The problem I get is when I rotate the project to true north the vertical bracing goes back on grid line and I want it to be show offset from grid.
Has anybody else had this problem and know how to rectify it ?
thanks
You said when you rotate the project then it acted weird. You may have confuse the orientation of your frame/beam. Did you try redrawing a frame with the new orientation. When you changed the orientation, did you rotate the objects or use the Manage location/position command? A screenshot would help to understand your point?
Motto: "No Post left behind" |
see the attachment, when i change the orientation to true north (using manage tab and rotating to true north command) the vb goes back on grid which i do not want.
any ideas ?
Vertical bracing symbolic line ??? |
Tue, Jun 4, 2013 at 7:33:50 AM
Revit 2014 Vertical Bracing Problems |
Thu, Feb 20, 2014 at 10:26:00 AM
Vertical and horizontal bracing connections |
Mon, Jun 24, 2013 at 7:18:38 AM
Vertical bracing line |
Sun, Jun 2, 2013 at 2:17:03 AM
Snaping to Lines |
Thu, Feb 9, 2012 at 9:53:32 AM
