Forums >> Community >> Newbies >> Hide Walls Below - New to Revit
Mon, Jan 16, 2012 at 11:34:51 AM | Hide Walls Below - New to Revit
berginarchitect
berginarchitect Avatar
4 Stars: 1 Votes
I've searched through past threads and haven't been able to find a solution to the problem I'm having.  I'm modeling the existing conditions of a two story building using Revit 2011...I completed modeling the basement/foundation plan and moved on to the first floor level.  Once I created a floor at the first floor level, I was no longer able to see the interior basement walls below, sounds perfect, right?  After I completed the first floor level and moved on to the second floor level, upon creating a floor at the second level, I am still able to see the first floor walls below!  I have tried recreating the floor, verifying the top constraints of the first floor wall, but I am having zero luck.
Short of selecting every first floor wall below and hiding it in that view, does anyone know of some setting that I can tweak to hide walls below?
Many thanks in advance, I'm at my wits end!
Mon, Jan 16, 2012 at 11:44:05 AM | Hide Walls Below - New to Revit
berginarchitect
4 Stars: 1 Votes
OK, so after I finally resorted to posting in this forum, I solved the problem.  On the floor plan properties, I had "first floor" level set as an underlay...Duh.
Fri, Sep 21, 2012 at 9:10:30 AM | Hide Walls Below - New to Revit
hifrank001
thanks; i had same issue these days and solved the problem with this thread.
Wed, Jul 23, 2014 at 4:26:55 AM | Hide Walls Below - New to Revit
Rashmor83
Thanx to this thread old but goldie....Smile
Wed, Sep 3, 2014 at 8:13:22 AM | Hide Walls Below - New to Revit
buday
I dude try view range in modifier make it all 0 amunt.i hope it will help
Structural walls in Architectural Model
Fri, Aug 6, 2010 at 9:51:37 AM
HOw Do i HidE ThOse Lines ?
Mon, Oct 30, 2006 at 9:03:35 PM
Hide insulation in MEP 2012
Wed, Sep 5, 2012 at 3:39:14 AM
Hide top of walls
Tue, Apr 28, 2009 at 3:38:49 PM
Hide Isolate
Fri, May 2, 2014 at 2:34:08 PM
Page generation time: 3.4512
