Forums >> Community >> Newbies >> gable mass in place model
Mon, Jan 16, 2012 at 10:31:54 AM | gable mass in place model
husam3
hello every body ,
i have to make gable mass in place family how can i do it , when i tried to made it its be flat not gable can you help me please ?
Mon, Jan 16, 2012 at 10:34:02 AM | gable mass in place model
Do you really need a mass or could you just model a gabel roof?
Mon, Jan 16, 2012 at 10:38:44 AM | gable mass in place model
husam3
no i need it amss not roof
Mon, Jan 16, 2012 at 10:41:08 AM | gable mass in place model
4 Stars: 205 Votes
Put some images of what you want please.
Mon, Jan 16, 2012 at 10:43:27 AM | gable mass in place model
husam3
i need to make a mass for building which is her shape cupe with gable roof so the total shape it will be gable mass
sorry i dont have pic
Mon, Jan 16, 2012 at 10:45:37 AM | gable mass in place model
Just extrude the form....
Mon, Jan 16, 2012 at 10:46:57 AM | gable mass in place model
husam3
so there is no way to make it in place ?
Mon, Jan 16, 2012 at 11:06:01 AM | gable mass in place model
Like this?
Mon, Jan 16, 2012 at 11:16:25 AM | gable mass in place model
husam3
YES , THAT WHAT I WANT
Mon, Jan 16, 2012 at 11:20:55 AM | gable mass in place model
  1. Create a reference plane in your plan view to work from.
  2. Switch do your elevation and turn on mass.
  3. Using the reference plane sketch the form - mass category.
  4. Set the extruded form depth.
Mon, Jan 16, 2012 at 11:23:01 AM | gable mass in place model
#11
husam3
THANK YOU SO MUCH , I LL TRY TO DO IT
APPRECIATED THAT
Mon, Jan 16, 2012 at 11:43:58 AM | gable mass in place model
#12
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If I understand this correctly, what about loading one of the predefined Mass Element Families that comes with REVIT ?
There is a gable family ready to go.
See Image.
Mon, Jan 16, 2012 at 11:53:59 AM | gable mass in place model
#13
husam3
yes i already used this one for some  building but others its has compecated edges so i cant use it beacause the edgs are not the same
Mon, Jan 16, 2012 at 11:54:57 AM | gable mass in place model
#14
husam3
my project is masre plan and i want to modeling all building as masses i hope i can explane it correctly
Mon, Jan 16, 2012 at 6:41:13 PM | gable mass in place model
#15
mhans
3 Stars: 10 Votes
If it's a lot of gables, would you like to try sketchup and import it to revit?
Motto: "No Post left behind"
Issue creating mass floor area schedule (mix of families & 'model in place' mass
Thu, Sep 27, 2012 at 7:05:36 AM
'forms' not available in 'in place mass' or components.please help
Fri, Aug 30, 2013 at 3:20:58 AM
Sweeping Solid In-Place Mass
Tue, Apr 27, 2010 at 3:30:38 AM
extruded generic model and mass floors (2012)
Fri, Sep 21, 2018 at 3:36:03 AM
Attatching an image to a 'Model in Place' mass
Fri, Apr 27, 2012 at 9:36:34 AM
Page generation time: 2.3962
