13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Disapearing Floors
Anyone experiencing that floors will just delete themselves? If so how do you stop this?
When you move something that is attached to a floor I.E a wall, the move may cause to floor extrusion to become invalid and the floor will be deleted. I.E a line may become too short in the floor extrusion or lines may cross up. An error message should come up saying extrusion invalid delete instances?
I'm sure you could select a floor and think you have something else selected. I have done this also. I have deleted a floor in Vectorworks not knowing I had it selected. Tab through and make certain of what you have selected.
To avoid this issue. When you receive this message, cancel out of the command and try moving the element with disjoin ticked. This will remove associations.
Thank you
Disapearing Import file |
Tue, Dec 26, 2006 at 4:31:10 PM
Joining the Geometry of two floors |
Wed, May 14, 2008 at 5:46:12 AM
Draftng Lines disapearing below roof?!?! |
Fri, Feb 22, 2008 at 3:58:03 PM
Grouping Floors |
Mon, Aug 22, 2005 at 3:47:49 PM
Dead horse still kicking - walls and floors strategy |
Tue, Oct 2, 2007 at 1:36:25 PM
