Forums >> Revit Building >> Technical Support >> curtain wall grid and mullions
Mon, Jan 16, 2012 at 6:30:29 AM | curtain wall grid and mullions
tarsamo
I am trying to put grids on a blank curtain wall with curtain grid botton. but instead of grids it creats mullions and I can not move, copy or delete them. does any one know what the problom is? How can i delete the mullions or move them?
Mon, Jan 16, 2012 at 7:52:17 AM | curtain wall grid and mullions
If you can not move or delete your mullions, then your curtain-wall is predefined. That is that the spacings and mullion types are pre-defined in the CW type.
We often use pre-defined curtain-walls for initial placement but then we change the type to one we call manual.  It has no pre-definitions.  Then we can modify the CW as we need.
Mon, Jan 16, 2012 at 6:13:06 PM | curtain wall grid and mullions
tarsamo
thank you but how do I make a manual curtain wall/
Mon, Jan 16, 2012 at 6:36:31 PM | curtain wall grid and mullions
mhans
3 Stars: 10 Votes
There's tons of tutorials on youtube, here's one http://www.youtube.com/watch?v=t7SjghbL4Jk
Motto: "No Post left behind"
Curtain wall grid
Sat, May 28, 2016 at 9:58:45 AM
Curtain walls: Different spacings between mullions.
Tue, Jun 2, 2015 at 9:46:09 AM
curtain wall aggrivation
Wed, Mar 7, 2012 at 11:58:04 AM
Revit 2013 Curtain Wall Variable Grid Spacing
Thu, Jul 18, 2013 at 2:10:54 AM
Angled and Straight Curtain Wall Mullions
Mon, Feb 27, 2012 at 12:19:11 PM
Page generation time: 1.4483
