14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> wrong underlay showing
1 Posts No Rating |
I have a problem with the underlay of my basement. When I click the first floor as underlay, revit shows the 2nd floor, and when I click the 2nd floor, it shows the 3rd floor as underlay. I have this problem only with my basement level. In other levels, underlay works fine.. Any help would be great!
8 Posts No Rating |
Just noticed that this is happening on my latest project. Did you find any resolution? Noticed there was not much for settings for the Halftone/Underlay drop down.
67 Posts No Rating |
I have an issue of the underlays only being ceiling plans... even for floor plans. there must be a way to edit what views are linked to the underlay. im in revit 2014
Just click on the view and in the view properties, pick a different underlay or none from the underlay drop down.
my problem is that if I choose "00 Lower Level" for underlay while in a floor plan it does not underlay the floor plan, but the ceiling plan instead. It does this for every floor plan and ceiling plan. It may have something to do with the fact that I had deleted all the origional floor plans because I had duplicates of them that I used instead. What I need is a way to edit the list of underlay options to put floor plans in there and not ceiling plans.
thanks
It does sound like you have a mess because you have a process problem. You probably created it by deleting floor plans and using ceiling plans instead. In most cases, you may not want to duplicate plan views, instead create your new views from the view/plan view tab.
I suggest you create valid plan views where you can set the underlays you want. You should be able to copy the annotative elements for the bad views to your valid view.
i have two main floors, upper and lower levels. I created some new plans and now if I assign an upper level underlay to any view it works fine. If I assign a lower level underlay to any view, it is the ceiling plan but with no ceilings, just light fixtures and walls... whatever. That is good enough. thanks for your time
Edited on: Mon, Jan 27, 2014 at 1:30:35 PM
Underlay |
Thu, Oct 11, 2012 at 8:15:33 AM
underlay not showing up |
Wed, Nov 18, 2009 at 4:34:06 PM
misguided underlay |
Tue, Feb 19, 2013 at 8:14:29 AM
Filled region showing up in an underlay |
Fri, Dec 8, 2006 at 5:11:22 PM
Underlay not showing |
Mon, May 12, 2014 at 3:57:09 PM
