18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Referenced view
10 Posts No Rating |
I have section tags that are referencing certian drafting views. One group of tags is referencing the wrong view, is there a way to change the referenced view without creating a new section tag? I have about 100 of them to change, it would be great if there was a easy fix. Any help would be greatly appreciated.
The only way would be to change the referenced drafting detail using copy paste. Otherwise, you have to create new reference tags. << This means edit the detail - swap them!
Edited on: Fri, Jan 13, 2012 at 12:37:47 PM
GENIUS!! Thank you. You saved me an hour at least!
Referenced views floating in space |
Thu, Oct 22, 2015 at 2:43:48 PM
Note with a referenced view |
Wed, Jun 29, 2011 at 1:32:52 PM
"Referenced From" Issue with Section Marks |
Mon, Feb 6, 2012 at 2:55:01 PM
referenced sections |
Wed, Apr 2, 2008 at 1:06:05 PM
export dwg with views not referenced |
Thu, Apr 29, 2010 at 4:23:32 AM
