Forums >> Revit Building >> Technical Support >> Beam system demo
Fri, Jan 13, 2012 at 12:03:53 PM | Beam system demo
lbeeman
Does anyone know how to show pieces of a beam system as demolished in the new construction phase?  It appears as if I can only demolish the whole system.
Fri, Jan 13, 2012 at 1:40:19 PM | Beam system demo
lbeeman
I'm still using Revit Architecture 2011.  FYI.
Fri, Jan 13, 2012 at 2:42:11 PM | Beam system demo
mhans
3 Stars: 10 Votes
I guess, you draw 2 beams and join them together. Draw one in one phase and the other in another phase.
Motto: "No Post left behind"
Fri, Jan 13, 2012 at 3:07:27 PM | Beam system demo
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
After a quick test it does appear that you CANNOT demo a beam within a beam system. Even using the TAB key to select the beam.
Even if you UnPin the beam Cryingwhich allows some movement but unfortunately no demo).
You'll have to 'Remove Beam System' which basically explodes it into individual beams.
Then you can demo.
Mon, Jan 16, 2012 at 11:46:32 AM | Beam system demo
lbeeman
Thanks for your help.  I thought as much.
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:20 PM
Adding a beam system issue
Sun, Jun 15, 2014 at 2:58:10 PM
Beam System Tag
Fri, Aug 14, 2009 at 3:09:33 AM
Schdule of Beam System
Tue, Jan 4, 2011 at 5:45:12 AM
beam system
Thu, Oct 15, 2015 at 7:32:17 AM
Page generation time: 0.1711
