9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Coping Tool not joining columns to bracing of SHS type families
1 Posts No Rating |
Hi Revit users,
This is my issue:
The Revit Coping Tool is not healing the joins between square hollow section bracing and square hollow section columns of the same external dims and same wall thickness. The first join works and then the bracing cuts into the column on the secound join, no matter the order that i use this tool. I have tried dragging the bracing extents, however this has little effect.
Regards,
RAH reviter
Version: Revit Architecture 2012
Spiffiset |
"Picture speaks louder than words." Do you have a screenshot?
Motto: "No Post left behind" |
Bracing not joining beams ;( |
Thu, Oct 27, 2011 at 11:21:43 AM
BEAMS JOINING COLUMNS problem |
Tue, Jun 30, 2015 at 7:41:51 AM
Truss - coping frame members |
Mon, Aug 16, 2010 at 5:51:35 AM
joining two round columns together |
Tue, Jul 16, 2013 at 6:28:05 AM
Unable to print all columns |
Fri, Aug 1, 2008 at 7:29:11 AM
