Forums >> Revit Building >> Technical Support >> Exported Keyboard Shortcut file is .xml format - can't open in Excel
Thu, Jan 12, 2012 at 6:21:30 PM | Exported Keyboard Shortcut file is .xml format - can't open in Excel
sattoji
I just installed Revit 2012 and want to take advantage of the editable keyboard shortcut file. When I export the file it is in .xml format, and my Excel (Office 2008 for Mac) can't open nor import the data correctly, it just comes in as long text strings. I researched on the web but am getting nowhere. Am I missing something obvious?
MacBook Pro 2.66 GHz Intel Core i7 running Windows 7 Pro 64-bit on Parallels 6
Fri, Jan 13, 2012 at 8:18:42 AM | Exported Keyboard Shortcut file is .xml format - can't open in Excel
I just exported mine in 2011 and had no problems.  I will test later on a 2012 machine.
I opened it as an xml table and excel said it had to create a schema for it - which it did.
Fri, Jan 13, 2012 at 9:25:13 AM | Exported Keyboard Shortcut file is .xml format - can't open in Excel
TKennedy
4 Stars: 8 Votes
Just out of curiosity, why are you wanting to edit the file directly instead of just working through the Revit interface?
Fri, Jan 13, 2012 at 11:41:37 AM | Exported Keyboard Shortcut file is .xml format - can't open in Excel
sattoji
Today I got the file to open in Excel. For whatever reason the .xml extension read as an Adobe GoLive document when I tried to open it directly on the Mac side. I couldn't get Excel to recognize it except by converting it to a text file, which lost the delimiters in the file.
I think the problem was that the Open File window in Excel was set to "all Excel files" instead of "all Office Documents". Once I set it to all Office Docs it recognized the .xml file and it opened fine.
Thanks for the support.
I wanted to open it in a text editor so I could search for multiple instances of the same shortcut... I was having conflicts in previous versions.
Keyboard Shortcuts Won't Open/Show
Tue, Feb 26, 2013 at 11:09:04 AM
Can I change the 'ctrl + Tab' shortcut to switch between windows to a (2) digit?
Thu, Jun 26, 2014 at 2:51:35 PM
Exporting Schedules into excel format
Fri, Mar 13, 2015 at 5:53:44 AM
Keyboard Shortcut file location for Vista
Mon, Oct 13, 2008 at 1:35:19 PM
Keyboard shortcut
Fri, Apr 3, 2015 at 12:43:42 PM
Page generation time: 2.7584
