Forums >> Revit Building >> Technical Support >> Revit for Construction Documents
Thu, Jan 12, 2012 at 4:17:49 PM | Revit for Construction Documents
rambo6
4 Stars: 4 Votes
Is there anyone using Revit to make CDs? Are you implenting Revit to make interior elevation, exterior elevations, details, plans, RCPs, etc.? Any advice on moving to try and use Revit to tackle any of these?
thanks
Thu, Jan 12, 2012 at 4:22:19 PM | Revit for Construction Documents
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I would ssy it safe to say we are all using REVIT for CDs.
Fri, Jan 13, 2012 at 1:20:04 PM | Revit for Construction Documents
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
that is the whole point.
Fri, Jan 13, 2012 at 1:24:21 PM | Revit for Construction Documents
If your not, then why are you using Revit?
Fri, Jan 13, 2012 at 1:29:16 PM | Revit for Construction Documents
rod23
5 Stars: 4 Votes
If you are still using AutoCAD for CD's, then you are outdated. With Revit you can change a window size IN THE SCHEDULE and have it instantly change on the interior and exterior elevations, RCP, plan, and 3D Perspectives.  I'll be moved on to doing video animations and full color renderings while you are chasing around changes all day.
http://www.turbosquid.com/Search/Artists/Revitaoist
Fri, Jan 13, 2012 at 1:31:37 PM | Revit for Construction Documents
mhans
3 Stars: 10 Votes
You have 5 bars and you are not using Revit for CDs. There must be something wrong. Seriously, I think  you are still thinking of going back to Autocad, don't you will loose your reputation. Smile
Motto: "No Post left behind"
Mon, Jan 16, 2012 at 1:25:26 PM | Revit for Construction Documents
JHanby
3.5 Stars: 3 Votes
Our firm started with a small maintenance garage project when we first started with Revit then worked up to a bigger scale project and then an even bigger scale.  Worked for us as far as switching over.  HTH. Smile
Jill
Mon, Jan 16, 2012 at 2:56:18 PM | Revit for Construction Documents
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'm interested in how someone has 5 bars and only 43 posts ?
Mon, Jan 23, 2012 at 1:04:49 PM | Revit for Construction Documents
rambo6
4 Stars: 4 Votes
Thanks for the input. I was just curious. I just got out of school and started in a firm and it is my job to introduce Revit. I was just asking...
Mon, Jan 23, 2012 at 1:08:46 PM | Revit for Construction Documents
rambo6
4 Stars: 4 Votes
I use this to help me perform tasks in school. I have no need for 5 bars. I was just looking for help. Does anyone know of any good websites for equipment blocks? or converting any other family files to revit?
Edited on: Mon, Jan 23, 2012 at 1:45:29 PM
Mon, Jan 23, 2012 at 1:15:13 PM | Revit for Construction Documents
#11
The posts above were not put downs.  I think the users were just dumbfounded by your question considering your score.
Equipment blocks?  Mighty broad term.  AutoDESK Seek site has many manufacturer families.  And some manufacturers have their own CAD and Revit files.  You can also create families from Google warehouse objects but do that at the risk of these items being just guesses as to size etc.
Mon, Jan 23, 2012 at 1:16:00 PM | Revit for Construction Documents
#12
rambo6
4 Stars: 4 Votes
I had been using Revit for exterior renderings, so far.
Mon, Jan 23, 2012 at 1:26:03 PM | Revit for Construction Documents
#13
mhans
3 Stars: 10 Votes
Yes, with our limited knowledge of what your circumstances are, we are only trying to help and most of the times we start by asking questions. Smile
Mon, Jan 23, 2012 at 1:29:12 PM | Revit for Construction Documents
#14
rambo6
4 Stars: 4 Votes
Ok I understand now. I have only ever used Revit for 3d renderings, which is why most of my posts have been concerning that. I appreciate the help. As far as moving to complete constructions documents, my firm produces drawings for Restaurants.  So are there any other websites for cooking equipment? other than http://smartbim.reedconstructiondata.com/ and revitcity.com? thanks.
Mon, Jan 23, 2012 at 1:30:57 PM | Revit for Construction Documents
#15
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'm still curious in how someone gets 5 bars and only 43 posts ?
How does that happen exactly ?
Not that I care but I've been contributing to this site for 7 years.
Construction Documents - Architectural
Sun, Jan 8, 2006 at 10:37:43 PM
pdf of Construction Documents
Wed, Mar 22, 2006 at 4:11:06 PM
Firm - making transistion from AutoCadd to Revit [ 1 2 ]
Wed, Sep 10, 2008 at 1:50:09 PM
15
Construction documents
Tue, Jul 18, 2006 at 4:56:27 PM
AIA Best Practices - Organizing Construction Documents
Thu, Mar 20, 2014 at 2:36:36 PM
Page generation time: 3.1389
