Forums >> Revit Building >> Technical Support >> Revit FBX to 3D Max 2011 causes black or unresponsive viewports
Thu, Jan 12, 2012 at 1:43:21 PM | Revit FBX to 3D Max 2011 causes black or unresponsive viewports
bucksy99
I am having essentially trouble with 3D studio max but it is related to Revit. Maybe (hopefully) somebody can help.
when I expert a revit model into fbx and then link it into 3D Max the viewports become either black or unresponsive. I have tried pretty much everything I can think of: changing the display driver to open GL, installing the latest driver for my graphics card, etc
Now, I know that the black viewports are a relatively common problem and are usually fixed with the new driver or switching to open GL. However I have that problem ONLY when I link an fbx model from Revit. I do not think it has anything to do with the size of the model, since it is a relatively simple interior model and I have done more complex things in 3D Max alone without ever encounting this problem.
Any suggestions would be greatly appreciated.
I am running Revit 2012 and 3D Max Design 2011 on a Windows 7 , 64 bit platform.
The graphics card is an Nvidia GeForce GT 520
Thanks again
Thu, Jan 12, 2012 at 2:10:35 PM | Revit FBX to 3D Max 2011 causes black or unresponsive viewports
mhans
3 Stars: 10 Votes
Try import instead of link. If the model show up correctly, then there's something wrong with the model. Purge the revit file and try again.
Motto: "No Post left behind"
Thu, Jan 12, 2012 at 5:41:48 PM | Revit FBX to 3D Max 2011 causes black or unresponsive viewports
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
you probably need to update your FBX plugin for 2011 since you are using a newer version of Revit.
Thu, Jan 12, 2012 at 8:34:33 PM | Revit FBX to 3D Max 2011 causes black or unresponsive viewports
bucksy99
thanks for the suggestions.
importing the file and updating fbx give me still the same results.
It must have something to do with the Revit file though. I tried a very simple model and it worked without a problem.
The other thing that is odd is, that once the fbx file is linked, the file link manager shows the file with the red flag as it woulnd't be current and needs to be updated. Even though that is not the case.
will keep trying.
Thu, Jan 12, 2012 at 8:43:24 PM | Revit FBX to 3D Max 2011 causes black or unresponsive viewports
bucksy99
found out what the problem is!
it is the lights! When I delete the lights out of the revit model, the fbx file loads in fine.
It even takes noticable longer to load than before.
Other files (with lights) I tried from previous Revit versions load fine. So there must be something going on with the light families (or new rendering engine in revit?) that max doesnt agree with. Not sure what the workaround it is at this point.
Will try to experiment some more tomorrow.
Fri, Jan 13, 2012 at 10:35:33 AM | Revit FBX to 3D Max 2011 causes black or unresponsive viewports
bucksy99
it basically came down to one light that I downloaded. The light source was modeled. When I changed that to a light source as it is in the current revit lights the whole model imported just fine.
Thanks for the help.
Fri, Jan 13, 2012 at 10:46:07 AM | Revit FBX to 3D Max 2011 causes black or unresponsive viewports
alabaster2513
3.5 Stars: 25 Votes
glad to hear you were able to figure it out, I've never heard that one before. kudos
Fri, Jan 13, 2012 at 11:29:51 AM | Revit FBX to 3D Max 2011 causes black or unresponsive viewports
mhans
3 Stars: 10 Votes
Nice for you to share your troubles and your solution. Sometimes we can figure out things on our own, we just need to talk to someone to share it with. Here, you'll get that lots of someone.
REvit 2011>>FBX>>Max Design 2011 using File link manager
Thu, Jan 27, 2011 at 9:34:41 AM
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
Revit 2009 to FBX Import into MAX 9?
Wed, Jan 21, 2009 at 1:12:22 PM
Revit 10 Model to FBX to 3Ds Studio Max Design lighting problem
Sat, May 1, 2010 at 12:55:25 PM
Exporting FBX file from Revit to 3Ds Max
Wed, Sep 30, 2020 at 1:36:49 PM
Page generation time: 3.8748
