Forums >> Revit Building >> Technical Support >> Material Change, Revit freezes
Thu, Jan 12, 2012 at 12:02:26 PM | Material Change, Revit freezes
esahnow
Whenever I go to edit a material, Revit temporarily freezes for 3-5 minutes then comes back active. Anyone else have this issue? Autodesk had nothing for me. I'm using Revit Architecture 12.
Eric Sahnow
Project Lead/Designer
Thu, Jan 12, 2012 at 12:16:53 PM | Material Change, Revit freezes
How many view windows do you have active?  Each one has to be redrawn.
Thu, Jan 12, 2012 at 12:17:36 PM | Material Change, Revit freezes
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Have not seen this myself.
Does it happen in all files or certain files?
Even in a new empty project with a 2012 template ?
Maybe try turning off Hardware acceleration.
Make sure you have the latest RAC 2012 Build > http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=9262001
Maybe close other apps in case there is a wee conflict.
Thu, Jan 12, 2012 at 1:21:48 PM | Material Change, Revit freezes
esahnow
It happens to all files, even clean templates. It doesn't matter how many windows I have open. I'll try turning off hardware acceleration.
Eric Sahnow
Thu, Jan 12, 2012 at 2:18:04 PM | Material Change, Revit freezes
esahnow
Turning off hardware acceleration did not help.
Eric Sahnow
Thu, Jan 12, 2012 at 4:17:12 PM | Material Change, Revit freezes
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Are running the latest and greatest build of REVIT ?
You can use the link above to download but the latest Build of REVIT Architecture 2012 is:
Update 2 build 20110916_2132
Thu, Jan 12, 2012 at 4:27:49 PM | Material Change, Revit freezes
esahnow
Yes, I've got the latest updates.
Eric Sahnow
Thu, Jan 12, 2012 at 4:36:28 PM | Material Change, Revit freezes
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
What type and config. is the computer ?
Also try searching this discussion site for answers:
http://discussion.autodesk.com
You may find some answers there.
Dropping a note to your reseller never hurts either.
Thu, Jan 12, 2012 at 4:44:25 PM | Material Change, Revit freezes
esahnow
I've got a HP laptop
Windows 7 Premium
2.20GHZ i7 core
8GB RAM
Radeon HD 6770M video card
Eric Sahnow
Revit 2011 Hang on Material Painter
Thu, May 27, 2010 at 7:50:17 AM
Revit freezes when opening sheet views
Fri, May 11, 2012 at 5:23:01 PM
Revit freezes when I do a 'Save As'???? Need help urgently!
Fri, Aug 9, 2013 at 10:53:11 AM
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
Colour/Material change in project?
Thu, May 24, 2007 at 2:21:03 AM
Page generation time: 1.8797
