Forums >> Community >> Newbies >> Merging Curved Roof with Hip
Wed, Jan 11, 2012 at 11:40:03 AM | Merging Curved Roof with Hip
mcapri92
I am still trying to learn Revit so there may be a simple solution I am just overlooking.  The attached file is a small study I was doing for a half round bay window.  The desire was to have a half turret which would then return to the main hip roof like a dormer.  I tried creating it as all one roof and Revit gave me a full turret merging into the hip.  I tried creating the half turret with the return and it said it could not create the roof (when I created it in place over the bay).  So I created a half turret and then tried to use the roof join command...couldn't join.  Created an infill roof between the two and it still would not let me use the roof join tool.  Could use the standard join but it left the portion of the turret and infill inside.  It appears that Revit is having an issue with the curved roof merging with the hip as when I move the curve away from the hip a few feet things merge much better.  Tried everything I know at this point and still can't get it to work for an quick interior rendering.
Thanks,
Tim
Wed, Jan 11, 2012 at 12:32:07 PM | Merging Curved Roof with Hip
Words just don't work here.  Pleas post a small image of what you want.
Wed, Jan 11, 2012 at 1:59:33 PM | Merging Curved Roof with Hip
mcapri92
I was afraid it might have gotten confusing.  Attached are two images.  The exterior is what I would like the final roof to be.  The interior image shows the roof projecting into the space which is where the problem is.
Thank you
Curved Hip Roof
Sun, Apr 30, 2017 at 5:39:20 AM
Hip Roof Issue
Mon, Mar 24, 2008 at 1:30:08 PM
Partial Hip Roof
Tue, Jun 26, 2007 at 3:22:10 PM
Hip Roof with curved flared ends eaves
Fri, Apr 24, 2020 at 5:53:04 AM
Can't get Gable roof to Join Hip roof
Wed, Aug 20, 2014 at 3:56:33 PM
Page generation time: 0.7123
