Forums >> Revit Building >> Technical Support >> Color Scheme Edits
Wed, Jan 11, 2012 at 10:21:45 AM | Color Scheme Edits
beccabecca11
Is there any way to change the "value" in a color scheme once it is created?
for example, I have an existing building and we are showing the "level" of renovations throughout the building: i.e. 1, 2, 3.  I have all of the areas defined but now would like to change the value to say 1-Minor, 2-Moderate, 3-Major.  Is there a way to do this without creating new values and then having to go and redefine all the areas on the plan?  Why can't I just go into the "value" column and change the wording?
Wed, Jan 11, 2012 at 10:30:11 AM | Color Scheme Edits
Your HELP file is a great resource.  Under:  Modifying a Color Fill Legend
To change the legend title
  1. In the drawing area, select the color fill legend.
  2. Click Modify | Color Fill Legends tabScheme panel (Edit Scheme).
  3. Edit the text for Title.
    NoteWhen you modify the legend title for a color scheme, all project views that use the color scheme are affected.
  4. Click Apply to view your changes. Click OK to exit the Edit Color Scheme dialog.
Wed, Jan 11, 2012 at 10:48:03 AM | Color Scheme Edits
beccabecca11
Thanks for your reply - however it does not answer my question (neither does the "great resource" HELP menu)
I do not wish to edit the Title. I wish to edit the Value
Wed, Jan 11, 2012 at 11:07:10 AM | Color Scheme Edits
I assume this is a room color scheme.  That value is the value you placed in the room parameter called "RENOVATIONS" .   Change it there.
Wed, Jan 11, 2012 at 11:35:19 AM | Color Scheme Edits
beccabecca11
no, you still aren't understanding. see the image I attached?  I entered a VALUE that said "Level 1" and created a color scheme, then selected each room that I wanted to be at "Level 1".  But now I want it to be "Level 1 Minor Renovations".  So I want to just edit (UNDER THE VALUE column) "Level 1".  But instead, I need to create a new value and call it "Level 1 Minor Renovations" and then go back to my plan and re-select each room and change it to the new value.
Does anyone else out there understand or have run into a similar problem?  is there no easy way around it?
Wed, Jan 11, 2012 at 12:20:52 PM | Color Scheme Edits
No, I don't think you understand.  "Value" is just the content of parameter that organizes this schedule.  Post an image of your room properties.
Wed, Jan 11, 2012 at 12:39:08 PM | Color Scheme Edits
beccabecca11
ok, here it is.
Suppose I had misspelled "minor renovations".  It shows up in my legend.  What if I want to change that?  I CANNOT.  I have to go into the "edit scheme" and create a new VALUE parameter with the correct word, then go and select the room on my plan that needs to be changed and select the new parameter from the element properties.  I don't want to do that, I simply want to be able to click on the parameter within the edit windo and change it.
Wed, Jan 11, 2012 at 12:44:50 PM | Color Scheme Edits
beccabecca11
" "Value" is just the content of parameter that organizes this schedule "
put another way, how do I EDIT the content of the parameter once it has been entered?  I can Add new ones, I can organize their order, I can change the color schemes... but can I EDIT THE ACTUAL TEXT OF THE CONTENT PARAMETER????
Wed, Jan 11, 2012 at 12:56:16 PM | Color Scheme Edits
As I posted earlier "That value is the value you placed in the room parameter called "RENOVATIONS" .   Change it there. "  Click on the room in the floor plan and edit the room properties!
Wed, Aug 15, 2012 at 5:43:23 PM | Color Scheme Edits
mhans
3 Stars: 10 Votes
Same dilemma using Revit 2013. I wanted to rename the word "Epoxy" to "EPOXY". I already assigned Epoxy to a lot of rooms and I don't want to go back and redo them. Is there a better way?
Motto: "No Post left behind"
color scheme disappear
Fri, Sep 24, 2010 at 7:49:22 PM
new color scheme entry error
Thu, Sep 18, 2014 at 1:42:54 PM
12
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:38 AM
Color Scheme Problems
Tue, Jun 26, 2007 at 11:53:16 PM
PNG- TRANSPARENCY- COLOR SCHEME
Sun, Sep 30, 2018 at 10:09:50 PM
Page generation time: 2.0512
