Forums >> Revit Building >> Technical Support >> Select all of one linetype in a view?
Tue, Jan 10, 2012 at 3:04:24 PM | Select all of one linetype in a view?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Is it possible to select all instances of one linetype in a view?  Suppose I created a custom linetype for red-lining some notes in a sheet and want to select all of those lines?  Is this possible?
The usual trick of right-click>select all instances is greyed out...
Thanks.
Tue, Jan 10, 2012 at 3:10:57 PM | Select all of one linetype in a view?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
you can select everything in the view then use filters to select the individual linetype
Tue, Jan 10, 2012 at 3:31:14 PM | Select all of one linetype in a view?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Ah, brilliant, thanks.  I had assumed it would group the linetypes together under one heading, but it separates them.
Handy Linetype
Sun, May 7, 2006 at 8:14:27 AM
How to add new linetype to family
Fri, Jan 3, 2014 at 10:01:49 AM
Help: Linetype with text?
Thu, Jun 19, 2008 at 1:54:25 AM
Framing Plan Objects Visiblity (2008)
Wed, Oct 17, 2007 at 5:47:13 PM
Revit equivalent of AutoCAD's Linetype Generation?
Tue, Feb 24, 2009 at 7:39:33 AM
Page generation time: 2.4261
