Forums >> General Discussion >> Wishlist >> Escalator
Mon, Jan 9, 2012 at 1:31:38 PM | Escalator
kelava
Need an escalator for a public space that can be modified to any angle (including 0 degrees).
I tried all the ones posted here for download and none of them could be uploaded to Revit 2012.
Or if somebody can show me how it can be designed. That would be even better.
Mon, Jan 9, 2012 at 2:00:34 PM | Escalator
I don't understand your problem.  I opened the first two escaltors directly in 2012.
Mon, Jan 9, 2012 at 2:08:05 PM | Escalator
kelava
hmm... I get a message that current file is being updated to its current version and then it just disappears as if I didn't load anything. I figured it was just not compatible with Revit 2012.
Has anybody had or heard of such issues?
Mon, Jan 9, 2012 at 2:20:55 PM | Escalator
I always open directly then load it into the project.
Mon, Jan 9, 2012 at 2:30:35 PM | Escalator
kelava
I've never done it that way... can you elaborate?
I was able to open it directly in Revit, but unable to load that same file into my project.
Mon, Jan 9, 2012 at 2:38:51 PM | Escalator
Simple - With the project open, you open the family, then pick load into project on the ribbon.
Mon, Jan 9, 2012 at 2:54:40 PM | Escalator
kelava
Same thing happens as if I loaded it directly from the project. But apparently it does open the object, because now I get a message saying it already exists in the project, do I want to replace it.
But I am still unable to see it in the project.
Mon, Jan 9, 2012 at 2:57:21 PM | Escalator
What view are you trying to place it from?  Also note the category of the item has to be turned on!  I see that the one escalator tells you what category it is done in.  You can always see that in the family editor under category and parameters.
Mon, Jan 9, 2012 at 3:01:09 PM | Escalator
kelava
I tried both the plan view and 3D
Mon, Jan 9, 2012 at 3:12:34 PM | Escalator
kelava
In the Family Editor tab I only have "load into project" option.
Mon, Jan 9, 2012 at 3:20:55 PM | Escalator
#11
Please spend some time with your HELP.  You can find how to set categories there.  I also suggest you download the families guide.  You can find a link to that on the AutoDESK site.  Click on your HELP pulldown and pick "Documents on the web"  You will find the guide there.
Mon, Jan 9, 2012 at 4:14:51 PM | Escalator
#12
kelava
Thanks for the help.
Parametric travelator/escalator?
Sun, Jan 24, 2016 at 7:54:11 PM
Editing height of escalator?
Fri, Mar 6, 2009 at 5:28:40 PM
parameter change
Sat, May 9, 2009 at 1:43:20 PM
Families' View Range
Thu, Jan 21, 2010 at 8:43:29 AM
Escalator Help
Wed, Jun 6, 2012 at 12:50:55 AM
Page generation time: 0.1262
