Forums >> General Discussion >> Revit Project Management >> Multi-storey areas?
Mon, Jan 9, 2012 at 12:05:38 PM | Multi-storey areas?
guitarchitect
I'm working on an 8-storey condominium, and I'm generating a unit schedule. Each unit is a line-item (Unit #, type, size), and there is a schedule which provides me with a unit count of each type (studio, 1B, 2B, etc). Is there a way that I can generate a single unit from areas on two storeys? I have townhouses and penthouses which all need to show up on the schedule as a single item.. I can un-itemize instances and calculate totals (and assign the same unit # to two different areas), but my unit count still shows those areas as a "new" unit, so I'll get 14 units where I have 7 x 2storeys.
I really do need a workaround for this - otherwise the schedules are almost useless for me.
Mon, Jan 9, 2012 at 12:43:40 PM | Multi-storey areas?
Are you using area plans or room areas?
Have you tried adding a shared parameter to your areas (rooms) called unit number?  Then use that number as a sort.
Mon, Jan 9, 2012 at 12:51:34 PM | Multi-storey areas?
guitarchitect
I'm using area plans. As noted, I have turned off the itemizing of units and turned on the totals. visually this looks fine - the units show up with the correct areas. The two floor's areas are still counted as two different units though, which inflates my unit counts and throws off the totals.
Mon, Jan 9, 2012 at 12:53:34 PM | Multi-storey areas?
guitarchitect
to clarify: the way I got the areas to show up correctly was by changing the "number" parameter of the area to be the same on the two different floors. but it gets counted as two units.
apartment areas
Sun, Apr 20, 2008 at 10:31:50 PM
Tips on setting up a multi storey and multi unit residential model
Wed, Aug 3, 2011 at 8:35:26 AM
Can't see first storey walls in first storey plan view
Mon, May 5, 2014 at 9:02:22 PM
Adjusting project levels for multi storey building
Wed, Oct 11, 2006 at 8:33:31 AM
MULTI-CATEGORY SCHEDULE
Wed, Dec 29, 2010 at 4:45:25 AM
Page generation time: 0.8489
