Forums >> Revit Building >> Technical Support >> Wall Cut Pattern Plan View vs. Section
Fri, Jan 6, 2012 at 10:40:55 AM | Wall Cut Pattern Plan View vs. Section
bdsharon
Here's what I'm looking to do.  I have a wall that consists of metal studs, rigid insulation, and brick veneer.  My plan view and section detail levels are set to medium.  In plan view I want each of my wall cut patterns (all 3 are different) to show up, which I've accomplished.  In section view I want all my wall cut patterns to show up except the metal stud pattern.  The only way I've found to do this is to create a masking region over the stud area.  Is there some kind of setting that I am not seeing or any better way to accomplish what I'm trying to do?
Fri, Jan 6, 2012 at 11:11:39 AM | Wall Cut Pattern Plan View vs. Section
You can over-ride graphics in view by element and turn off all the cut patters for a wall.  The key here is ALL.  You can not turn of single layers.
Fri, Jan 6, 2012 at 11:19:21 AM | Wall Cut Pattern Plan View vs. Section
bdsharon
That's what I was afraid of (ALL).  Thanks for the info.
Brick cut pattern
Tue, Jul 24, 2007 at 8:52:01 AM
Cut Pattern in Plan vs Section
Tue, Aug 25, 2009 at 8:47:59 AM
cut pattern in section
Wed, Jun 1, 2011 at 4:30:59 AM
Wall cut patterns
Fri, Jun 16, 2006 at 1:29:23 PM
Material Surface and Cut Pattern accuracy
Mon, Jan 28, 2008 at 8:25:08 AM
Page generation time: 6.7605
