Forums >> Revit Systems >> Technical Support >> Infilling element replaced by a later phase insert must be the same type as the
Fri, Jan 6, 2012 at 5:33:19 AM | Error message - when trying to alter existing wall types
jayceedee
Hi All
I'm currently working on a refurbishment project and have drawn the existing and proposed elements.
I'm now trying to update some of the existing walls to a new wall type which will allow me to show them as existing blockwork (which will show hatched with view filter applied).
On some of the walls where I have existing doors as downtakings and also new doors added I am getting the error message;
"Infilling element replaced by a later phase insert must be the same type as the insert's host."
Short of deleting the existing and new doors, altering the wall type, then redrawing the doors, is there a simpler work around?
Any help would be appreciated.
Thanks
John.
Edited on: Fri, Jan 6, 2012 at 5:38:17 AM
Fri, Jan 6, 2012 at 8:09:11 AM | Infilling element replaced by a later phase insert must be the same type as the
I have never seen this message.  Please tell us what your wall type is and both doors.
Fri, Jan 6, 2012 at 8:46:24 AM | Infilling element replaced by a later phase insert must be the same type as the
jayceedee
Sorry - should have clarified;
I'm in UK using Revit Architecture 2012.
Walls - existing wall is revit basic wall copied (duplicated) and altered to be 140mm thick.New wall is a duplicate of the first wall with a type mark added to allow me to cross hatch this particular wall type even though it is existing. The cross hatch wall is working in most instances (including walls which have new / existing doors in) but I am getting this message on various walls, all of which include existing doors demolished as well as new doors.
The doors are families created in-house, some of which are based on standard revit doors, others which have been built from scratch.
I have just copied the file and reduced it to a smaller part of the plan area which contained the problem and it now works (ie, the wall now allows me to alter its type) - without deleting any of the elements actually within the wall.
File size is around 30mb. 2 storey building with around 200 rooms. Should I split the project? Could size of file be the issue?
Fri, Jan 6, 2012 at 2:15:42 PM | Infilling element replaced by a later phase insert must be the same type as the
Size is not an issue and do not split the project.  We did a project that was 220 meg plus additional linked structural and MEP models in vers 2008 on a 32 bit machine.  So your 30 meg is nothing.
Thu, Jan 12, 2012 at 8:04:30 AM | Infilling element replaced by a later phase insert must be the same type as the
jayceedee
WWHub - thanks for your response - I'll persevere with the file as it is and try and see if I can come across a solution for the error as I go.
Wed, Jan 25, 2012 at 9:49:58 AM | Infilling element replaced by a later phase insert must be the same type as the
hank
3.5 Stars: 3 Votes
I'm having the same issue but what I've learned so far is that when you have an existing wall with a hosted element that gets demolished, revit creates an infill element automatically to close up the hole.
Thu, Jan 31, 2013 at 1:24:11 PM | Infilling element replaced by a later phase insert must be the same type as the
tbryanm
1 Stars: 1 Votes
So what was the actual takeaway from your response WWHub? That your 200mb project is cooler than his 30mb project?? What kind of solution is that?? Wasted bandwidth, and my time.
Thu, Jan 31, 2013 at 1:40:53 PM | Infilling element replaced by a later phase insert must be the same type as the
Interesting comment - shows you didn't read the thread.
Thu, Jan 31, 2013 at 2:37:52 PM | Infilling element replaced by a later phase insert must be the same type as the
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I believe that the point was that if its not a problem with 200meg project it should not be a problem with a much smaller 30meg project.  Resurecting a post from a year ago without adding any input or asking a question is a waste of everyones time.
Infill Elements
Wed, Dec 24, 2014 at 1:08:06 PM
Infilling elements containing sweeps
Wed, Mar 18, 2009 at 3:59:35 PM
Can't delete infilling element without deleting its insert or host.
Tue, Sep 8, 2009 at 3:29:45 PM
Hide infilling lines
Mon, Aug 22, 2011 at 2:51:33 AM
Copying doors from one phase to another
Thu, Feb 7, 2008 at 2:29:40 PM
Page generation time: 0.6271
