Forums >> Workflow & Implementation >> Worksets >> Visibility/Graphics override based on Workset
Fri, Jan 6, 2012 at 12:40:55 AM | Visibility/Graphics override based on Workset
gprakash
Is there an option to override VG properties based on worksets?
I have few worksets in a single building block. Each workset contains multiple elements (Beams,Columns and walls). I need to show each workset in different materials/colors on 3D view. Please suggest how I can acheive this.
Thanks.
Edited on: Fri, Jan 6, 2012 at 12:48:30 AM
Fri, Jan 6, 2012 at 3:07:31 AM | Visibility/Graphics override based on Workset
gprakash
I forgot to add - I have created muliple 3D views to show each workset in each 3D view.
Fri, Jan 6, 2012 at 8:36:12 AM | Visibility/Graphics override based on Workset
Materials are fixed per element, not per view.  If you want multiple material options, use Design Options.  Worksets are not meant for this use.
Fri, Jan 6, 2012 at 11:08:36 AM | Visibility/Graphics override based on Workset
TKennedy
4 Stars: 8 Votes
You can set up a filter for worksets in V/G. I don't know that you will be able to change the materials, but you will be able to change the shading colors. I have done that myself just to be able to quickly check to make sure elements are on the correct workset.
Mon, Jan 9, 2012 at 3:59:46 AM | Visibility/Graphics override based on Workset
gprakash
Thanks for both the suggestions.
With Filter, I could go upto selecting the Workset and not to further steps. May be I have to learn more.
I duplicated the families of Beams, Columns and Walls based on workset names to show different materials/colours across the worksets. It worked for me to show the same assigned material/colour in all other 3D views where the respective worksets are visible.
Thanks.
Thu, Jan 19, 2017 at 2:35:04 PM | Visibility/Graphics override based on Workset
archigrafix
5 Stars: 4 Votes
With 3 clicks and Graphic Studio it's possible to override it like this:
  1. Hide temporarily undesirable worksets, keeping 1 workset on.
  2. Select all objects visible
  3. Click on the graphical change in the Graphic Studio dialog
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Hide a workset in a link
Sat, Sep 20, 2008 at 10:04:45 AM
Family Worksets in Visibility/Graphics
Thu, Feb 9, 2006 at 1:28:02 PM
Adjusting footing appearence.
Wed, Feb 10, 2016 at 9:35:06 AM
Workset VG in View Template
Mon, Nov 24, 2008 at 8:27:08 PM
Visibility Graphics - locks up
Fri, Aug 29, 2008 at 11:30:19 AM
Page generation time: 1.0104
