Forums >> Revit Building >> Technical Support >> sloped walls
Sun, Dec 11, 2005 at 5:20:00 PM | sloped walls
tekeda1
Is it possible to draw sloped walls? I am currently modeling a parking garage in Revit. The 7'-0" high precast conc. spandrel walls are sloped to match the ramp angles in the north and south elevations.
Sun, Dec 11, 2005 at 5:41:44 PM | RE: sloped walls
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes you can, just use in place family (wall type) and use solid blend, define top and bottom of wall... HTH let me know if you have trouble with that Winking
Integrator
KarelCAD
Mon, Dec 12, 2005 at 3:58:58 PM | RE:
tekeda1
HTH
I am not sure what you mean by "in place family (wall type). I am pretty new to Revit and I am not 100% up on the technical lingo.
Mon, Dec 12, 2005 at 4:43:11 PM | RE: sloped walls
TomDorner
4.5 Stars: 25 Votes
I would place reference planes ( use elevation view to place them), give them a name then simply place walls and attach the tops/bottoms of the walls to the correnct reference plane name (highlite wall then click on the attach button)
Tue, Dec 13, 2005 at 7:59:54 AM | RE: sloped walls
tekeda1
Thanks for the help, your suggestion worked really well. Next problem: How can I add reveals or sweeps to that sloped wall that are parallel to the top or bottom. By default sweeps and reveals are parallel to the floor line? If it isn't possible I will just use model lines. Tim
Tue, Dec 13, 2005 at 11:18:53 AM | RE: sloped walls
Rythmick
5 Stars: 2 Votes
There are offset parameters in the sweep properties to control placement.
Tue, Dec 13, 2005 at 3:44:39 PM | RE: sloped walls
tekeda1
the offset parameters only work for walls that are parrallel to the gound. What I mean, is that if the top of my wall is sloped, and I have a revaled defined in the wall style. the reveal runs parrallel to the ground, not the top of the sloped wall. If you could mock up a quick demonstration it would be appreciated.
Tue, Dec 13, 2005 at 4:57:54 PM | RE: sloped walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Apply as in-place family sweep then use the pick command to pick the edge you wish to apply it to and use the offsets to position it appropriately. HTH.
Thu, Dec 15, 2005 at 8:51:20 AM | RE:
tekeda1
HTH.
I still cannot get this to work, Would it be possible for you to mock up a small example?
Tim
Wed, Oct 13, 2010 at 11:54:58 AM | sloped walls
pgalla
Yes Draw the wall and cut a section full length of wall. Then view the section and pick the wall and pick Edit Profile. This will allow you to slope, step or cut openings in the wall/ Top Bottom middle.. When done Finish Sketch.
Wed, Oct 13, 2010 at 1:28:16 PM | sloped walls
4 Stars: 205 Votes
 Pgalla
"Yes Draw the wall and cut a section full length of wall. Then view the section and pick the wall and pick Edit Profile. This will allow you to slope, step or cut openings in the wall/ Top Bottom middle.. When done Finish Sketch."
This thread has 5 years and i don't understand how you can create a "SLOPE Wall" like you said... "Edit profile... this will allow you to slope..."   - How?
How do you have walls attach to sloped surfaces of masses?
Thu, Nov 23, 2006 at 11:51:12 PM
Sloped walls joins problem
Sat, Oct 16, 2010 at 6:17:23 PM
sloped walls
Thu, Jul 21, 2005 at 12:06:16 PM
Can Revit draw a vertically sloped axi line?
Mon, Jul 16, 2012 at 7:22:26 AM
Sloped Curtain Walls- How to?
Tue, May 5, 2009 at 9:46:15 AM
Page generation time: 0.4459
